Can't get Mobian on PinePhone to recognise USB-C docking bar
There is a usbc mod on youtube that 'unlocks' the port. It's called "usb-c fix on the pinephone". All you do is heat 2 small pieces while tweezing them off. The hard part is taking it apart and putting it back together. I haven't even tested mine yet. The youtube video references ubports but supposedly there is no software fix at all so if mine balks I'll probably do it if it can't be replaced with one that works. The video is less than 6m and it's very detailed so looks rather easy. I already own a soldering iron like the one pinephone makes and they are cheap.
RE: Can't get Mobian on PinePhone to recognise USB-C docking bar - by Avatars - 05-11-2021, 05:39 AM
  PinePhone - boot from microSD laserpyramid 7 574 11 hours ago
Last Post: aular
  pinephone virtual keyboard aular 4 349 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 232 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,036 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,795 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 608 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,364 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 497 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,686 12-22-2023, 03:44 PM
  Mobian PIN changed after update! Mwo87 21 17,741 12-02-2023, 11:53 PM
Last Post: Karrenbrady
