Provide power in via Pi-2 header
(12-11-2016, 12:10 PM)BenCranston Wrote: Well, that fully explains the issues I've been having.  I'm going to re-route the power over to the EULER bus and test again.  I'm worried however that I might have damaged something on the Pine64 by back-powering via the Pi-2 interface...
So, @pfeerick can you comment on @ciclopez assessment of the schematic?  Thanks.
So, have you been powering the Pine through the Pi-2 Bus and the microUSB port at the same time? I won't recommend doing that, but maybe the Pine has some protection for that use-case and your Pine could be fine, otherwise the MT3608 or your power sources might have been damaged, or maybe they just overheat.
I just did some measurements on the Pine and providing an input voltage of 4.97V through DCIN, the output voltage in the pins 2 & 4 of the Pi-2 Bus is 5.24V (this comes from MT3608) So I think it won't be possible to bypass the MT3608 by shorting Pins 4 & 8 in the Euler Bus, as the currents flowing from MT3608 to the power source could be of several Amps... unless I'm missing something.
Does anybody have an idea to bypass the power regulator?
Provide power in via Pi-2 header - by BenCranston - 06-13-2016, 07:55 PM
RE: Provide power in via Pi-2 header - by g_t_j - 06-14-2016, 06:14 AM
RE: Provide power in via Pi-2 header - by g_t_j - 06-15-2016, 05:17 AM
RE: Provide power in via Pi-2 header - by ciclopez - 12-11-2016, 12:53 PM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 02:23 PM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 03:03 PM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 04:26 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,101 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,578 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,530 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,358 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,811 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,353 03-18-2017, 09:18 AM
Last Post: Luke
  any danger from using 2 power sources at same time? dkryder 3 6,949 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,359 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 33,176 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 6,813 10-02-2016, 04:35 AM
Last Post: pfeerick
