Provide power in via Pi-2 header
(06-14-2016, 03:25 AM)pfeerick Wrote:
(06-13-2016, 07:55 PM)BenCranston Wrote: Is it possible to provide power to the Pine64 via the Pi-2 header.  I understand the Euler power can be used for this, but I'm specifically after pushing 5V in via pins 2 & 4 via the Pi-2 header.  Can someone verify that I'll not damage the Pine doing that?  I've got a Pi-Hat that provides power, supervision & backup battery.  It's a "back power" design  : https://github.com/raspberrypi/hats  the link talks about powering via the GPIO header.
Thoughts?
I can confirm that you can power the pine64 with 5v via the Pi-2 connector, with +5v on 4, and GND on 6. When the power jumper is set to DC5v (as opposed to BAT), pints 2&4 appear to be connected to the 5v power in path from the USB, and also connect to the Euler DC-in header.
that's great!  thanks for the detailed response.
Provide power in via Pi-2 header - by BenCranston - 06-13-2016, 07:55 PM
RE: Provide power in via Pi-2 header - by BenCranston - 06-14-2016, 05:06 AM
RE: Provide power in via Pi-2 header - by g_t_j - 06-14-2016, 06:14 AM
RE: Provide power in via Pi-2 header - by g_t_j - 06-15-2016, 05:17 AM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 02:23 PM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 03:03 PM
RE: Provide power in via Pi-2 header - by g_t_j - 03-08-2017, 04:26 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,092 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,541 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,526 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,337 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,768 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,336 03-18-2017, 09:18 AM
Last Post: Luke
  any danger from using 2 power sources at same time? dkryder 3 6,926 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,315 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 33,139 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 6,794 10-02-2016, 04:35 AM
Last Post: pfeerick
