Battery gauge issue (mainline kernel)
I'm trying to use Debian on a Pinebook Pro using the official bullseye installer.  (I'm aware of the unofficial installer!)
Mostly, it works quite well! For the record:
 * the installer created an additional partition (dummy partition to protect the bootloader, maybe?) that confused u-boot; deleting the partition fixed the problem (I plan to reproduce the unofficial installer's nice partition scheme later);
 * the screen remains blank (I installed using a serial cable) because the kernel gets confused by the video + usb-c port; this can be worked around by removing
&cdn_dp {
    status = "okay";
from the .dts (in the kernel sources), rebuilding the .dtb, and inserting the .dtb in /etc/flash-kernel/dtbs. (Information from https://www.reddit.com/r/PINE64official/...ne_kernel/ );
 * the battery gauge is not working (this is the reason for this post);
 * there is something wrong with the audio output, which I have not investigated (the uart/audio switch is set to uart, for serial output, it would make sense to try setting it to audio first).
From dmesg, I see a few messages related to the battery gauge:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.0-3-arm64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.1) #1 SMP Debian 5.10.13-1 (2021-02-06)
[    0.000000] Machine model: Pine64 Pinebook Pro
(snip)
[    7.150366] power_supply cw2015-battery: Not all required supplies found, defer probe
[    7.150384] cw2015 4-0062: Failed to register power supply
(snip)
(The two lines about cw2015 are repeated a few times, later.)
My understanding is that cw2015 support has been mainlined and should work with a mainline kernel.  I don't really understand what the "Not all required supplies found" message is about, but dmesg does not seem to have errors relating to the DC input not the USB-C input.  This is the only occurrence of "power supply" in these messages.
The same errors appear with the original .dtb file, so this is not a side effect of the above change.
Do you know what is causing the cw2015 driver to fail?  Any suggestion for a fix or workaround would be highly appreciated!
Best regards,
Lionel
Battery gauge issue (mainline kernel) - by lfourquaux - 04-03-2021, 10:12 AM
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,272 09-07-2023, 09:38 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 751 08-18-2023, 02:06 AM
Last Post: juliamenendez
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 953 08-18-2023, 01:58 AM
  kernel module that supports usb-c hdmi alexandre 16 14,475 05-14-2023, 09:58 PM
Last Post: rathofkhan3
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 1,312 05-10-2023, 04:51 AM
Last Post: Vinay
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,257 12-09-2022, 12:43 PM
Last Post: as365n4
  Manjaro update: wxgtk dependency issue Vinay 5 2,494 09-09-2022, 12:03 PM
Last Post: Vinay
  bootloader menu to pick a kernel - what is the current situation in in early 2022? maxtothemax 4 3,109 02-05-2022, 03:04 PM
Last Post: maxtothemax
  Kernel panics solostian 17 14,099 01-26-2022, 08:08 AM
Last Post: TRS-80
  Kernel 5.17 will improve VP9 support? jiyong 1 2,103 01-16-2022, 08:26 PM
Last Post: xmixahlx
