Are you interested in using UEFI on Pine64 or other arm board as the board's firmware?
Yes, it would be interesting if it works.
65.63%
21
Yes, it's interesting, but where the download link?
6.25%
2
Maybe, but for me uboot is enough.
21.88%
7
I am happy with uboot and religiously deny to use Uefi, because it comes from evil corporations!
6.25%
2
What's Uefi? Can it run Kodi?
0%
0
32 vote(s)
UEFI for Pine64
(06-20-2016, 06:38 AM)z4v4l Wrote: no, those aren't old boards, they are current. this is not allwinner SoC's boards, and their uboot doesn't support much. features are just not implemented.
For the sake of clarity, do these boards have names? If they are very new, then their situation may be very similar to Pine64 and the work adding support for the missing features might be already under way.
Quote:uboot on the other hand is a not structured, not documented mess. in order to get how to work for it, one needs learn through its entire codebase, it would not be easier and not that fun at all.
U-boot does have a bit of documentation and it is easy/usable enough. I have already provided two links to you in this discussion thread. I'm pretty sure that you can find most of the needed information yourself if you put some effort into it.
(06-20-2016, 07:50 AM)MarkHaysHarris777 Wrote: UEFI may make some sense for these tiny boards from an educational standpoint and from a security standpoint, as long as major corporations don't control it.
Yes, modern ARM systems rely on the firmware remaining active all the time and providing some services for the operating system running under it. At the very minimum the firmware is providing the PSCI interface, which is used for bringing up secondary CPU cores and implementing SMP. In the case of older 32-bit Allwinner chips, the U-Boot bootloader is responsible for starting this firmware and it is fully open source. In the case of Allwinner A64, the firmware is maintained not as a part of U-Boot, but as a separate ATF project. Things are a little bit more complicated by the fact that Allwinner SoCs also have a supplementary OpenRISC core,  which can provide some assistance for implementing a decent suspend-to-ram support and power management handling in general. This part of code is closed source in the Allwinner's BSP, but it is more or less optional and the mainline U-Boot & Linux kernel can run without it. Moreover, we can compile and run arbitrary code on the OpenRISC core too, but just have not implemented a usable firmware for it yet. As mentioned earlier, UEFI is a useful standard, it already has basic support in U-Boot and things will improve even more in the future.
Alternative firmware & bootloader implementations are surely welcome. But from the purely practical point of view, they need to bring something useful to the table in order to successfully compete with the existing solutions. Especially considering that the existing solutions are not standing still either.
The corporations can't have control even if they wanted to because Allwinner SoCs are perfectly open source friendly and don't require any signed blobs. The first stage bootloder code starts with full privileges and is not restricted by the boot ROM in any way. You don't normally have this kind of complete unrestricted freedom with the SoCs from Samsung or other big corporations. It is in fact one of the reasons why Allwinner is so popular and has an active open source community around it.
UEFI for Pine64 - by z4v4l - 06-11-2016, 03:02 PM
RE: UEFI for Pine64 - by ssvb - 06-11-2016, 03:40 PM
RE: UEFI for Pine64 - by z4v4l - 06-11-2016, 05:03 PM
RE: UEFI for Pine64 - by longsleep - 06-11-2016, 04:08 PM
RE: UEFI for Pine64 - by ssvb - 06-11-2016, 06:02 PM
RE: UEFI for Pine64 - by z4v4l - 06-12-2016, 06:40 AM
RE: UEFI for Pine64 - by ssvb - 06-12-2016, 10:56 AM
RE: UEFI for Pine64 - by z4v4l - 06-12-2016, 04:44 PM
RE: UEFI for Pine64 - by ssvb - 06-20-2016, 05:14 AM
RE: UEFI for Pine64 - by z4v4l - 06-20-2016, 06:38 AM
RE: UEFI for Pine64 - by MarkHaysHarris777 - 06-20-2016, 07:50 AM
RE: UEFI for Pine64 - by ssvb - 06-20-2016, 08:46 AM
RE: UEFI for Pine64 - by xalius - 06-20-2016, 12:20 PM
RE: UEFI for Pine64 - by z4v4l - 06-20-2016, 01:30 PM
RE: UEFI for Pine64 - by ssvb - 06-20-2016, 02:42 PM
RE: UEFI for Pine64 - by z4v4l - 06-20-2016, 03:50 PM
RE: UEFI for Pine64 - by ssvb - 06-24-2016, 02:52 PM
RE: UEFI for Pine64 - by z4v4l - 06-24-2016, 03:43 PM
RE: UEFI for Pine64 - by z4v4l - 06-27-2016, 06:01 PM
RE: UEFI for Pine64 - by z4v4l - 08-31-2017, 03:27 PM
RE: UEFI for Pine64 - by z4v4l - 06-24-2018, 03:06 PM
  Pine64 as squeezebox touch replacement Learnincurve 12 27,909 01-13-2021, 02:11 AM
Last Post: Learnincurve
  Pine64 E-ink screen - Android projectileobjects 4 9,571 12-03-2020, 03:03 PM
Last Post: Silk
  Pine64 based IP KVM tuaris 0 3,954 08-06-2020, 12:05 AM
Last Post: tuaris
Information Pine64 Head Unit Zoidiano0 100 141,741 11-19-2019, 04:35 AM
Last Post: rogatip79
  PINE64 to allow use of SATA disk on network/FTP mwelbourne 10 15,598 11-18-2019, 04:09 PM
Last Post: evilbunny
  How to setup VNC on your Pine64 (Debian, SSH, headless) pine64nutz 20 42,552 04-16-2019, 08:00 AM
Last Post: hg6806
  Setup Pine64+ with OP-TEE stdys 0 3,535 09-13-2018, 03:23 PM
Last Post: stdys
  Domoticz + PINE64 Z-Wave Module + Open Z-Wave klliew 4 9,650 04-19-2018, 02:23 AM
Last Post: Harlan Mueller
  Pine64 as Security Camera / Baby Monitor utdrmac 2 7,113 02-01-2018, 07:49 AM
Last Post: davidbrucs
Photo Nextcloud running on Pine64 gbjensen 1 6,032 01-18-2018, 05:51 AM
Last Post: Luke
