Booting Linux/Debian from the eMMC
Okay, I've been searching like mad to get my RockPro64 back up and running. I figured out the serial (the jumper to select 3v3 is important). It would work for a little while then not. At least now I have a backup board but I'll put that to good use.  Big Grin
Now I've been searching the site for how to copy over the Debian image (Armbian) to the emmc and then booting from emmc. I ran this:
cat /tmp/Armbian_21.02.1_Rockpro64_buster_current_5.10.12.img.xz | xz -d | dd bs=30M of=/dev/mmcblk2
Fdisk shows:
# fdisk -l /dev/mmcblk2
Disk /dev/mmcblk2: 58.2 GiB, 62537072640 bytes, 122142720 sectors
Disklabel type: dos
Disk identifier: 0xcb08aa40
Device                      Boot   Start       End Sectors  Size  Id  Type
/dev/mmcblk2p1      32768 3571711 3538944       1.7G 83 Linux
I attempted to boot (SW4 removed), SD and eMMC installed. Only boots to SD.
Pointers please
thanks
Booting Linux/Debian from the eMMC - by linuxha - 03-02-2021, 08:49 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 510 03-25-2024, 12:12 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 845 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,485 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,316 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 564 04-23-2023, 11:02 PM
Last Post: Thisone
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,014 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,354 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  RockPro64 linux console video mode callegar 0 887 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,234 04-30-2022, 03:57 PM
Last Post: TRS-80
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 2,432 02-19-2022, 06:44 AM
Last Post: sigmaris
