C GPIO
(08-25-2016, 08:24 AM)martind1983 Wrote: One more question. All the pins led out on the board and which are also dedicated to some peripherals I have to first turn off special functionality before using them as normal GPIO?
No, not necessarily.
... as long as the pins (channels) are not actually being used 'now' you can use them for what-ever you want. But, that's a big if.  If a driver is running that uses the channel, you will need to stop and unload the driver... but, you don't necessarily have to edit the dtb|dts in order to do this.
That said, it is best to use GPIO pins that are 'free' first.  On the diagram , the green and then maybe the blue. The main exception right now is the pin(7) GPIO04 which is s-pwm and used for the LCD backlight... because it is on a pwm channel even though you can turn it on and off (if you have the correct base address, or use sysfs) it still doesn't work right, because it is 'very' dim ... and, it has a pwm signal on it.  In this case you must not only edit the dtb|dts, but also unassociate the pin, and you need to stop the driver and unload it (a lot of work, just use another GPIO pin).
C GPIO - by igna09 - 06-10-2016, 12:41 PM
RE: C GPIO - by martinayotte - 06-10-2016, 01:52 PM
RE: C GPIO - by igna09 - 06-10-2016, 02:16 PM
RE: C GPIO - by martinayotte - 06-10-2016, 03:10 PM
RE: C GPIO - by martind1983 - 08-24-2016, 09:55 AM
RE: C GPIO - by igna09 - 06-11-2016, 02:51 AM
RE: C GPIO - by martinayotte - 08-25-2016, 07:35 AM
RE: C GPIO - by martind1983 - 08-25-2016, 08:24 AM
RE: C GPIO - by MarkHaysHarris777 - 08-25-2016, 11:17 AM
RE: C GPIO - by martind1983 - 08-29-2016, 01:30 AM
RE: C GPIO - by martind1983 - 08-29-2016, 03:50 AM
RE: C GPIO - by MarkHaysHarris777 - 08-29-2016, 05:25 AM
RE: C GPIO - by martind1983 - 08-31-2016, 03:47 AM
RE: C GPIO - by pfeerick - 08-31-2016, 04:14 AM
RE: C GPIO - by martind1983 - 08-31-2016, 04:36 AM
RE: C GPIO - by MarkHaysHarris777 - 08-29-2016, 05:04 PM
RE: C GPIO - by MarkHaysHarris777 - 08-31-2016, 04:09 AM
RE: C GPIO - by KnReLe - 08-31-2016, 07:27 AM
RE: C GPIO - by martind1983 - 09-01-2016, 05:08 AM
RE: C GPIO - by MarkHaysHarris777 - 09-01-2016, 05:29 AM
RE: C GPIO - by martind1983 - 09-01-2016, 08:04 AM
RE: C GPIO - by KnReLe - 09-01-2016, 08:52 AM
RE: C GPIO - by martind1983 - 09-01-2016, 09:06 AM
  RPi.GPIO python module for Pine A64/A64+ aquilegia 98 131,601 12-15-2022, 08:40 PM
Last Post: Fadazo
  fm transmitter with gpio weasel18 2 4,829 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,599 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 11,132 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,216 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,854 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,607 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,775 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 21,177 08-17-2017, 01:21 PM
Last Post: martinayotte
  GPIO fiq capability joseph 3 6,096 11-10-2016, 06:07 PM
Last Post: joseph
