Problem making SD card
(06-14-2016, 02:38 AM)pfeerick Wrote:
(06-08-2016, 09:54 PM)Tam Dl Wrote: I have a 10 speed SD card 32gig.  I went to the Pine Wiki and tried to download the 32G version of remix.  That file appears to be larger than the usable space on a 32G card.  Should I therefor try the 16G version?  What is going on here, what good is a 32G memory card that is already filled with 32G of stuff?
Um, I may be missing something here... but when I go to the pine64 wiki page, the image for RemixOS is only a 1.2GB download, and is for a 8GB card (not for 16GB or 32GB).
The disk image is in a zip file (making it so the image of the 8GB memory card is only a 1.2GB file) so you need to extract that first, and then follow the setup instructions near the top of the wiki page:
Quote:Setup Steps:
  1. Download the preferred OS image from below OS links and extract the img file from the archive using 7-Zip
  2. Use Win32 Disk Imager or Linux dd command to write the img to a SD card
  3. Insert the SD card into Pine A64 board and boot it up
I do not believe you use Phoenix for any of the images except for the Android one. And once you have booted up most of the linux images on the wiki, you can resize the filesystem to use the full card.
There are PhoenixCard images for both Android and RemixOS. You have to go specifically to the Software Release section of the wiki. There are more options available there.
Problem making SD card - by Tam Dl - 06-08-2016, 09:54 PM
RE: Problem making SD card - by Ghost - 06-08-2016, 10:33 PM
RE: Problem making SD card - by Tam Dl - 06-09-2016, 01:36 AM
RE: Problem making SD card - by Ghost - 06-09-2016, 12:24 PM
RE: Problem making SD card - by NexusDude - 06-12-2016, 07:24 AM
RE: Problem making SD card - by Ghost - 06-14-2016, 01:09 AM
RE: Problem making SD card - by NexusDude - 06-17-2016, 10:50 PM
RE: Problem making SD card - by Tam Dl - 06-14-2016, 12:19 AM
RE: Problem making SD card - by Ghost - 06-14-2016, 04:23 AM
RE: Problem making SD card - by pfeerick - 06-14-2016, 02:38 AM
RE: Problem making SD card - by Ghost - 06-14-2016, 02:58 AM
RE: Problem making SD card - by pfeerick - 06-19-2016, 07:48 PM
RE: Problem making SD card - by g_t_j - 06-14-2016, 06:53 AM
RE: Problem making SD card - by Ghost - 06-17-2016, 10:55 PM
RE: Problem making SD card - by Tam Dl - 06-18-2016, 12:21 AM
RE: Problem making SD card - by Ghost - 06-18-2016, 01:15 AM
RE: Problem making SD card - by willyfog - 06-19-2016, 01:50 PM
RE: Problem making SD card - by Ghost - 06-19-2016, 03:59 PM
Question External storage problem for pine64 Dani6102 4 1,721 08-22-2023, 08:36 AM
Last Post: gulshan212
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,602 05-19-2023, 07:43 AM
Last Post: crocspot
  Jack connector problem pinebug 0 1,537 11-10-2022, 01:46 PM
Last Post: pinebug
Exclamation Can't boot when SD card inserted kivox 5 8,046 03-15-2020, 06:00 AM
Last Post: kivox
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 4,063 04-19-2019, 08:26 AM
Last Post: psychedup
Photo Daughter Card SBC for P64 blue 5 7,058 08-22-2017, 07:51 AM
Last Post: blue
  Pine64 $15 card killed my $120 keyboard exa 22 27,648 01-04-2017, 09:01 AM
Last Post: skenn_ie
  overlapping partitions issue with resize of 8GB image put on 16GB sd card dkryder 10 12,092 10-05-2016, 11:32 AM
Last Post: dkryder
  problem connecting to Pine 64 store stephen fleming 2 4,361 09-24-2016, 08:57 PM
Last Post: stephen fleming
  SD card recovery TeaPack 8 8,709 08-07-2016, 07:35 AM
Last Post: xalius
