(06-08-2016, 09:54 PM)Tam Dl Wrote: I have a 10 speed SD card 32gig. I went to the Pine Wiki and tried to download the 32G version of remix. That file appears to be larger than the usable space on a 32G card. Should I therefor try the 16G version? What is going on here, what good is a 32G memory card that is already filled with 32G of stuff?
Um, I may be missing something here... but when I go to the pine64 wiki page, the image for RemixOS is only a 1.2GB download, and is for a 8GB card (not for 16GB or 32GB).
The disk image is in a zip file (making it so the image of the 8GB memory card is only a 1.2GB file) so you need to extract that first, and then follow the setup instructions near the top of the wiki page:
Quote:Setup Steps:
- Download the preferred OS image from below OS links and extract the img file from the archive using 7-Zip
- Use Win32 Disk Imager or Linux dd command to write the img to a SD card
- Insert the SD card into Pine A64 board and boot it up
I do not believe you use Phoenix for any of the images except for the Android one. And once you have booted up most of the linux images on the wiki, you can resize the filesystem to use the full card.
