Problem making SD card
(06-12-2016, 07:24 AM)NexusDude Wrote: Why not shrink each image down, slightly, so that they'll fit on a wide range of cards? There are bound to be variations in storage sizes, but why not go with the smaller standard (1000 MB = 1 GB, rather than 1024 MB = 1 GB)?
I've tried 32GB images of Android, RemixOS, and OpenHab, and none will fit on the 32GB SanDisk Ultra microSD cards I have. I'm using 16GB images, as a result. Are issues with Google Play due to that, I wonder?
Since I can't find a way to convert IMG to ZIP, I have no way to trim the fat myself. There's a web site that claims to be able to do it in the cloud, but none of my cloud accounts has 32GB of space.
I don't think zipping the image will help. You need an image file, not a zip file. Zip is just a form of file compression that allows you to shrink the file size down, for ease of storage and transfer. Most files need to be unzipped again before they can actually be used.
Problem making SD card - by Tam Dl - 06-08-2016, 09:54 PM
RE: Problem making SD card - by Ghost - 06-08-2016, 10:33 PM
RE: Problem making SD card - by Tam Dl - 06-09-2016, 01:36 AM
RE: Problem making SD card - by Ghost - 06-09-2016, 12:24 PM
RE: Problem making SD card - by NexusDude - 06-12-2016, 07:24 AM
RE: Problem making SD card - by Ghost - 06-14-2016, 01:09 AM
RE: Problem making SD card - by NexusDude - 06-17-2016, 10:50 PM
RE: Problem making SD card - by Tam Dl - 06-14-2016, 12:19 AM
RE: Problem making SD card - by Ghost - 06-14-2016, 04:23 AM
RE: Problem making SD card - by pfeerick - 06-14-2016, 02:38 AM
RE: Problem making SD card - by Ghost - 06-14-2016, 02:58 AM
RE: Problem making SD card - by pfeerick - 06-19-2016, 07:48 PM
RE: Problem making SD card - by g_t_j - 06-14-2016, 06:53 AM
RE: Problem making SD card - by Ghost - 06-17-2016, 10:55 PM
RE: Problem making SD card - by Tam Dl - 06-18-2016, 12:21 AM
RE: Problem making SD card - by Ghost - 06-18-2016, 01:15 AM
RE: Problem making SD card - by willyfog - 06-19-2016, 01:50 PM
RE: Problem making SD card - by Ghost - 06-19-2016, 03:59 PM
Question External storage problem for pine64 Dani6102 4 1,754 08-22-2023, 08:36 AM
Last Post: gulshan212
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,620 05-19-2023, 07:43 AM
Last Post: crocspot
  Jack connector problem pinebug 0 1,544 11-10-2022, 01:46 PM
Last Post: pinebug
Exclamation Can't boot when SD card inserted kivox 5 8,072 03-15-2020, 06:00 AM
Last Post: kivox
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 4,077 04-19-2019, 08:26 AM
Last Post: psychedup
Photo Daughter Card SBC for P64 blue 5 7,086 08-22-2017, 07:51 AM
Last Post: blue
  Pine64 $15 card killed my $120 keyboard exa 22 27,763 01-04-2017, 09:01 AM
Last Post: skenn_ie
  overlapping partitions issue with resize of 8GB image put on 16GB sd card dkryder 10 12,124 10-05-2016, 11:32 AM
Last Post: dkryder
  problem connecting to Pine 64 store stephen fleming 2 4,374 09-24-2016, 08:57 PM
Last Post: stephen fleming
  SD card recovery TeaPack 8 8,733 08-07-2016, 07:35 AM
Last Post: xalius
