Problem making SD card
(06-09-2016, 01:36 AM)Tam Dl Wrote: "The actual image that is burned is much smaller than 32GB, around 460MB to just over 1GB, depending on which image is burned."
That is good to know, the actual file is a huge pig though, and I don't really get it, I suppose the point is that the image has to cover the whole card, so it is large, but there is lots of space in there.  So far, relatively powerful new computers are choking on this file
"Also, you shouldn't need to spend any money on unzipping software. You can use the trial version of WinRAR for as long as you like, and there are many free unzipping alternatives out there."
Can you suggest some.  I tried, cloudconvert, and it choked on Remix, though it did Phoenix and that file ran.  I used Winrar for an attempt on Linux/Pi project.  that one didn't work either, it might have been because I didn't run something like Phoenix to burn it, just tried to copy it.  Ancient history.  Comparatively though, the file sizes were small.
But the point is that I can't use the fee Winrar because I already burned through the trial, and they want me to pay.  They ask why I don't want to pay.  One of the options is that one thinks winrar is/ought to be free, which made me feel small, but come to think of it is my operating principle.  Is there a hack to perpetuate, winrar.  I tried deleting cookies and using a private session of Firefox.  Other family members have tried to open it, but it chokes everything in sight.
"Pre-burned cards were indeed available as options via Backerkit."
Geez, I bought everything else under the sun.  Were they loaded with Remix?
I think I have the process for Phoenix worked out.  It sounds simple enough, and I watched identical different videos on the process.  SO here is hoping.
Many thanks!!
Hey again.
Not sure why the file you are downloading is so large, it shouldn't be any bigger than 1.5GB maximum and should not take too long to download, even for a relatively old computer.
WinRAR should let you keep using it, even after any trial period has expired. So not sure what the issue is here either. Anyway, two alternatives are WinZip and 7-Zip.
I believe RemixOS was one of the options with the pre-loaded microSD cards, yes.
Good luck with PhoenixCard. Remember, there is only one image of those available on the Software part of the Pine64 wiki that is intended for burning with PhoenixCard. All the other RemixOS images offered (8GB, 16GB, 32GB, 64GB) are designed for use with Win32DiskImager or via the dd command in a terminal on Macs or Linux-based systems.
Problem making SD card - by Tam Dl - 06-08-2016, 09:54 PM
RE: Problem making SD card - by Ghost - 06-08-2016, 10:33 PM
RE: Problem making SD card - by Tam Dl - 06-09-2016, 01:36 AM
RE: Problem making SD card - by Ghost - 06-09-2016, 12:24 PM
RE: Problem making SD card - by NexusDude - 06-12-2016, 07:24 AM
RE: Problem making SD card - by Ghost - 06-14-2016, 01:09 AM
RE: Problem making SD card - by NexusDude - 06-17-2016, 10:50 PM
RE: Problem making SD card - by Tam Dl - 06-14-2016, 12:19 AM
RE: Problem making SD card - by Ghost - 06-14-2016, 04:23 AM
RE: Problem making SD card - by pfeerick - 06-14-2016, 02:38 AM
RE: Problem making SD card - by Ghost - 06-14-2016, 02:58 AM
RE: Problem making SD card - by pfeerick - 06-19-2016, 07:48 PM
RE: Problem making SD card - by g_t_j - 06-14-2016, 06:53 AM
RE: Problem making SD card - by Ghost - 06-17-2016, 10:55 PM
RE: Problem making SD card - by Tam Dl - 06-18-2016, 12:21 AM
RE: Problem making SD card - by Ghost - 06-18-2016, 01:15 AM
RE: Problem making SD card - by willyfog - 06-19-2016, 01:50 PM
RE: Problem making SD card - by Ghost - 06-19-2016, 03:59 PM
Question External storage problem for pine64 Dani6102 4 1,618 08-22-2023, 08:36 AM
Last Post: gulshan212
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,505 05-19-2023, 07:43 AM
Last Post: crocspot
  Jack connector problem pinebug 0 1,485 11-10-2022, 01:46 PM
Last Post: pinebug
Exclamation Can't boot when SD card inserted kivox 5 7,916 03-15-2020, 06:00 AM
Last Post: kivox
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 3,980 04-19-2019, 08:26 AM
Last Post: psychedup
Photo Daughter Card SBC for P64 blue 5 6,937 08-22-2017, 07:51 AM
Last Post: blue
  Pine64 $15 card killed my $120 keyboard exa 22 27,106 01-04-2017, 09:01 AM
Last Post: skenn_ie
  overlapping partitions issue with resize of 8GB image put on 16GB sd card dkryder 10 11,886 10-05-2016, 11:32 AM
Last Post: dkryder
  problem connecting to Pine 64 store stephen fleming 2 4,275 09-24-2016, 08:57 PM
Last Post: stephen fleming
  SD card recovery TeaPack 8 8,513 08-07-2016, 07:35 AM
Last Post: xalius
