Automate checking whether the Pinecil is still in stock
Big Grin
Here is a quick way to see whether the Pinecil gets back in stock.
I've been meaning to get one, but it is out of stock. To automate my stalking of pine's website, i've written this python script and thought that I could share it if someone thinks that it's neat:
import requests as r
from tkinter import messagebox as m
import tkinter as tk
import os
url = "https://pine64.com/product/pinecil-smart-mini-portable-soldering-iron/?v=0446c16e2e66"
#don't show a main window
root = tk.Tk()
root.withdraw()
response = r.get(url)
source = response.text
startIndex = source.find("<title>")
endIndex = source.find("</title>")
if (startIndex == -1) or (endIndex == -1):
    m.showerror(title="could not check pine64.com", message="please check your internet connection")
    quit()
if("[Out of Stock]" in source[startIndex:endIndex]):
    print(source[startIndex:endIndex])
    m.showinfo(title="OUT OF STOCK", message="the Pinecil is stil out of stock, unfortunately")
else:
    choice = m.askquestion(title="IN STOCK", message="THE PINECIL IS BACK\nGo to the store?")
    if choice == 'yes':
        os.system("firefox "+url)
This will show the following when executed
https://ibb.co/XzLBd1P
https://ibb.co/XCcJb9D
the only thing left then is to add a menu item with the command:
python ~/checkPinecil.py
(replace "~/checkPinecil" with the path to your saved file)
Then you can easily check whether it is available Smile
P.s. I am aware of how useless this is, but I was bored and this is the result.
Best Regards, Julius
Automate checking whether the Pinecil is still in stock - by Julius_GU - 01-27-2021, 02:15 PM
  Connecting a power supply to the Pinecil jon_bondy 1 340 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 760 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 355 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,196 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 646 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,270 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,531 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,428 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,226 12-14-2022, 01:03 AM
Last Post: River
  Survey on Pinecil Tips, Please fill out River 0 1,242 11-06-2022, 02:43 AM
Last Post: River
