Firmware update issue
I had same issue in Pinecil Firmware Updater tool.
There are two cases I found so far:
- Pinecils, which needs mass-erase, else the uploaded firmware doesn't work
- Pinecils, which fails on mass-erase, without mass erase, uploading works and the firmware works good too.
So I made in the app this updating optional. Also note, that dfu-util v0.10 have some improvements.
So, use dfu-util v0.10, and if mass-erase fails for you, just remove it, and it should work finely.
Also known as gamiee
Firmware update issue - by admar - 01-16-2021, 07:36 AM
RE: Firmware update issue - by crenn - 01-20-2021, 04:19 AM
RE: Firmware update issue - by VaZso - 01-20-2021, 07:20 AM
RE: Firmware update issue - by crenn - 01-20-2021, 06:25 PM
RE: Firmware update issue - by housinit - 01-25-2021, 06:02 PM
RE: Firmware update issue - by housinit - 01-26-2021, 12:48 AM
RE: Firmware update issue - by VaZso - 01-21-2021, 04:29 AM
RE: Firmware update issue - by foobarney - 01-26-2021, 08:34 PM
RE: Firmware update issue - by tllim - 01-27-2021, 05:26 PM
RE: Firmware update issue - by User 21336 - 02-08-2021, 12:45 AM
RE: Firmware update issue - by VaZso - 02-08-2021, 08:24 AM
RE: Firmware update issue - by gamelaster - 02-16-2021, 07:52 AM
RE: Firmware update issue - by rkl - 04-03-2021, 09:38 AM
RE: Firmware update issue - by Markkjohnson - 01-15-2022, 07:07 PM
RE: Firmware update issue - by Markkjohnson - 01-15-2022, 07:15 PM
