01-14-2021, 09:34 AM
(This post was last modified: 01-14-2021, 09:36 AM by moonwalkers.)
(01-13-2021, 04:18 AM)Tharadash Wrote: Hi ndp
I'm also using Daniels Debian-Installer.
I noticed that since a couple of days, the boot process takes around 30-40 seconds instead of the usual 10-20.
Have you been able to get any console output from your install?
I at some point have seen my PBP also increase its boot time. Turned out the original MODULES=list in /etc/initramfs-tools/initramfs.conf got changed to MODULES=most, which is Debian's default. Probably the whole file got replaced during one of the updates, because I usually also set KEYMAP=y instead of its default KEYMAY=n and that was reset too. I run kernel 5.8.5 built with pbp-tools script, and with it I currently have set MODULES=dep. Works fine and boots pretty quickly.
P.S.: I also have MrFixit's v2.0 u-boot on eMMC and I've removed maxcpus=4 from /etc/default/u-boot together with the snippet in /etc/tmpfiles.d/ that re-enables big cores during boot.
This message was created with 100% recycled electrons
