BSD host of issues on reboot from fresh install
Exclamation
Greetings. The title says it all, sort of. I cannot get FreeBSD to boot after reboot. Gives me this error:
mountroot: waitingMounting from ufs:/dev/ufs/rootfs failed with error 19.
My system specs:
RockchModel: Pine64 RockPro64 v2.1
U-Boot TPL 2020.10 (Jan 07 2021 - 05:00:17)
FreeBSD-13.0-CURRENT-arm64-aarch64-ROCKPRO64-20210107-f2b794e1e90-255641.img.xz (Listed on this page:https://download.freebsd.org/ftp/snapsho...AGES/13.0/ )
Image uncompressed and written to eMMC module using dd
The full boot to kernel panic is posted at https://pastebin.com/BkxGCjsJ
Line 364 is where the error is printed.
The install was fresh and booted fine. The image gives you root with "root" as the password, and "generic" as the hostname. I added 2 users, changed the host name, and rebooted. Got this error several times before trying a fresh install on an SD card, then experiencing the same error on reboot. Reflashed both the SD card and eMMC module a couple of times each, did the above setup, then rebooted with the same result. According to another forum for TrueNAS other's were experiencing this and the issue was their BIOS or the newest version of BSD. You can read more about it there:
https://www.truenas.com/community/thread...-19.13620/
I am entirely new to BSD in any version but would like to start with running a headless FreeBSD on my home lab. I will take a step back and try previous versions but any help in diagnosing this, or manually booting, via the prompts would be appreciated. BSD is way over my head but this just seems like an exciting place to start. Thank you for your attention!
UPDATE
I switched images and found the one posted on December 24th, 2020 works even after reboot. (The image I was using was posted on January 7, 2020. I was confused and thought there was only one RockPro64 image. They have the same beginning and similar ends in the long link.
The working image: FreeBSD-13.0-CURRENT-arm64-aarch64-ROCKPRO64-20201224-3cc0c0d66a0-255241.img.xz
Quartz64, RockPro64, PinePhone Mobian, PineBook Pro, PineTime, and all the trimmings that make FOSS fun.
BSD host of issues on reboot from fresh install - by MNtinkerer - 01-11-2021, 02:26 AM
  OpenBSD install on eMMC without serial dcnetfan 1 134 04-12-2024, 02:06 AM
