Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
#84
Well it seems like today has been a really good day bug hunting within mmsd. I have been able to solve every bug that I can reliably reproduce, making mmsd much more stable for usage.
The one outstanding issue is whether mmsd works with MMS proxies that are IP addresses only. I have had someone test this issue on AT&T (change the domain to the IP address manually), and they reported success with mmsd, but said there may be an purple-mm-sms issue.
However, in either case, I unfortunately cannot test this issue. If someone can hunt down this issue (and find a fix, or show me where the fix needs to go), I would greatly appreciate it.
EDIT: so there is another outstanding issue, and that deals with suspending the actual modem. I see where it needs to go, but I can work on it later/tomorrow.
RE: Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! - by kop316 - 01-19-2021, 11:54 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,314 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 896 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,528 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 2,871 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,040 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,565 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,181 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 127,974 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,014 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,615 06-13-2022, 02:01 PM
Last Post: israel
