RockPro64 line out/headphones in Android 9
Ok, so it seems that line out/headphones jack works in Android 9 on RockPro, but I need to run this app before:
https://play.google.com/store/apps/detai...dset_testt
Without running it and clicking on Speaker Toggle there is no audio from audio jack. It seems that the headphones/line out cable is not detected.
So, how do I enable line out by default after boot? Now I have to run that Speaker Toggle after each boot when I want to use line out.
there must be some asound/alsa config some somewhere, but I was unable to find it.
I found this app better for that
https://play.google.com/store/apps/detai...eheadphone
It allows running after start and it can automatically set the desired output (although the outputs are reversed).
RockPro64 line out/headphones in Android 9 - by Wizzard - 11-20-2020, 04:15 AM
  Difficulty installing Android on Rockpro64 spammycheese 0 2,688 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 2,594 06-04-2022, 12:18 AM
Last Post: grobbs
  Android TV miguelangelaj 2 2,885 06-03-2022, 11:23 AM
Last Post: miguelangelaj
  Control Fan in Android miguelangelaj 2 2,368 06-03-2022, 11:22 AM
  Slash TV Android for RockPro64 Wizzard 12 10,789 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 2,615 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 24,500 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 13,826 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 3,934 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 27,485 02-13-2021, 12:52 AM
Last Post: chisteven
