FydeOS for You - Pinebook Pro
#25
(01-12-2021, 07:40 AM)dieselnutjob Wrote:
(01-08-2021, 02:47 AM)cefre00 Wrote: So I tried it out, typing these words from FydeOS right now. I think the peformance is superior, something you would look for in 2021. Watching a 60 fps 720p youtube video: no problem, 1080p not so much though. FydeOS seems to be nice, but there is a little screenflickering which I only encountered on kernel 4.4 Debian on this rig before, very strange. I think ChromiumOS is the go with this machine or terminal Linux, because GUI Linux is just way too slow.
EDIT2:
And now my Manjaro installation is not booting anymore in the EMMC. Big Grin Unbelievable...
I also could not get FydeOS to boot from SD card.
I followed the instructions, and FydeOS does now boot from SD card but the original Manjero does not.
Specifically I followed the instructions substituting X for 2 because Manjaro is on /dev/mmcblk2
I also noticed when installing uboot-pinebookpro-bsp that this conflicted with uboot-pinebookpro which was removed.
1. What did I do wrong?
2. Is there a way to get Manjaro working again?
If not then it's slightly annoying but not a disaster.  I might even reimage the EMMC with ChromeOS for a while to play with it.
This goes back to what I mentioned earlier. BSP uboot and mainline kernels don't play very well together. You could try booting a linux from SD, and writing pcm720's bsp uboot and see if that works any better for you.
That's actually all you have to go to get manjaro back up; boot in from SD, replace the uboot on the emmc, reboot from emmc.
my setup is a bit different (i have CrOS on my emmc, and boot linux's from SD) so I'm not 100% why it's not booting correctly :/ you may be able to find appropriate assistance/support on manjaro's forum.
FydeOS for You - Pinebook Pro - by also1412 - 11-17-2020, 08:56 PM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 11-18-2020, 04:54 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-18-2020, 09:30 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 11-18-2020, 09:34 AM
RE: FydeOS for You - Pinebook Pro - by clover - 11-18-2020, 10:05 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-18-2020, 03:01 PM
RE: FydeOS for You - Pinebook Pro - by also1412 - 11-18-2020, 10:24 PM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-19-2020, 08:12 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 11-19-2020, 08:45 AM
RE: FydeOS for You - Pinebook Pro - by clover - 11-19-2020, 02:21 PM
RE: FydeOS for You - Pinebook Pro - by also1412 - 11-19-2020, 09:26 PM
RE: FydeOS for You - Pinebook Pro - by wove - 11-24-2020, 07:17 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 11-24-2020, 09:41 AM
RE: FydeOS for You - Pinebook Pro - by wove - 11-24-2020, 12:00 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-06-2021, 04:52 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-07-2021, 08:15 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-08-2021, 02:47 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-12-2021, 07:51 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-12-2021, 09:52 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-12-2021, 10:35 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-12-2021, 06:54 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 03-06-2021, 02:27 AM
FydeOS for You - Pinebook Pro - by tophneal - 01-12-2021, 06:55 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-19-2021, 05:26 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-19-2021, 07:57 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 01-19-2021, 09:09 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-19-2021, 12:33 PM
RE: FydeOS for You - Pinebook Pro - by also1412 - 01-19-2021, 07:10 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-19-2021, 09:49 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 01-19-2021, 09:53 AM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-19-2021, 11:17 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 01-20-2021, 07:17 AM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-20-2021, 11:16 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 01-20-2021, 12:26 PM
RE: FydeOS for You - Pinebook Pro - by tophneal - 01-20-2021, 05:03 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-20-2021, 04:37 PM
RE: FydeOS for You - Pinebook Pro - by cefre00 - 01-26-2021, 11:24 AM
RE: FydeOS for You - Pinebook Pro - by Wizzard - 01-21-2021, 12:01 AM
RE: FydeOS for You - Pinebook Pro - by also1412 - 02-23-2021, 03:02 AM
RE: FydeOS for You - Pinebook Pro - by ImmyChan - 03-25-2021, 12:23 PM
RE: FydeOS for You - Pinebook Pro - by Mangled - 11-14-2021, 03:36 PM
RE: FydeOS for You - Pinebook Pro - by Mangled - 01-09-2022, 03:31 PM
  Which OS can I actually run a 1080p pinebook non-pro? Scott104 1 2,728 10-09-2021, 02:47 PM
Last Post: TRS-80
Question FydeOS privacy policy? TDC_PBP 1 2,901 09-07-2021, 06:14 AM
Last Post: ImmyChan
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 3,502 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  CrOS boot from sd, now pinebook doesn't boot anymore qdoy55d9wkn8zw 7 10,997 06-22-2020, 06:23 AM
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 6,676 12-07-2019, 02:33 PM
Last Post: TDC_PBP
