Enabling UART2
Hardware: Pine H64 Model B
Hat: Elelabs Zigbee Raspberry Pi Shield
Step 1. Software
  • Started from fresh, simple, Armbian (by way of DietPi) install.
  • Disabled uart serial consoles with armbian-config/dietpi-config. (Or not, I re-enabled and used it later.)
  • Add:
    overlays=uart3
    to /boot/armbianEnv.txt
  • Reboot
  • confirm device creation with
    dmesg | grep tty
  • Output should be close to: [    3.819251] 5000c00.serial: ttyS3 at MMIO 0x5000c00 (irq = 26, base_baud = 1500000) is a 16550A
  • If you aren't sure peripheral is working use uart0 as a loop back source by connecting uart0TX(EXT Pin 1) to uart3RX( Pin 36), and uart0RX(EXT3) to uart3Tx(pin 37).  You can then use "screen /dev/ttyS3 baudrate" to read input
Step 2. Hardware
  • Identify adapter pins
                 ________
                 |  |  |  |3|2|
    Pin 1-->|1|  |  |  |4|
Adapter <---> UART3 Pins:
1 VCC <---> 3v3 - Pin 1
2 TXD <---> uart3 RX - Pin 36
3 RXD <---> uart3 TX - Pin 37
4 GND <---> GND - pin 39
Step 3. Reverse TX and RX that you hooked up backwards despite checking 3 times. Wink
Step 4.... Profit!
Reference:
https://wiki.pine64.org/wiki/PINE_H64
Files:
https://files.pine64.org/doc/Pine%20H64/...ematic.pdf  - NOTE - pin assignments differ from my particular model B
https://files.pine64.org/doc/Pine%20H64/...rev2.0.pdf - NOTE - These assignments DO reflect my Model B but I don't even know where this file came from anymore.
Enabling UART2 - by rgreen - 11-10-2020, 01:06 PM
RE: Enabling UART2 - by gnvdude - 11-11-2020, 06:45 PM
UART on the 40-pin GPIO bus - by rgreen - 11-12-2020, 03:56 PM
