Make your own Manjaro image
Kde is great but I like to run something a little lighter and just happen to think Budgie is  a little better. One approach would be to use pacman to add the budgie desktop package and choose your DE (desktop environment) at login, but I would rather not have to carry around all the KDE libraries for no reason. When I searched around for how to make my own "custom spin" I found some usefull info and thought I would share it here.
Contributing-to-manjaro-arm  was just what I needed. The link lists how to make a manjaro-arm image on an x86 machine.   While there are only a few official supported DE's, I found a way to work with that by modifying the default profiles.  For the remainder of this tutorial we will assume Budgie as the DE.
Picking up from the wiki section "Getting Profiles" we find that the relevant directory is
/usr/share/manjaro-arm-tools/profiles
and in this directory there are many prebuilt DE profiles (Gnome, KDE, XFCE etc).  These directories contain a list of packages that will be installed to achieve a specific DE. Budgie is based on Gnome  therefore I used the Gnome profile as a base.  I added the dependencies listed in the Arch-Wiki for Budgie-Desktop  to the Gnome config file, as well as the budgie-desktop package itself, and removed any packages I didn't want or need from the Gnome section. "Save as" to create a new profile named Budgie and then
sudo buildarmimg -d pbp -e whatever/name/you/used/at/Save as -v any/name/will/work -n
This will build your custom manjaro budgie img with all the packages that you specified in the profile that can be flashed to an SD card.  There is a slight difference in the command if you wish to install the the EMMC (that change is listed in the wiki).
There may be a more elegant solution for this process, but so far this the the best I have come across.  If there were a similar option for ubuntu , I have ideas there as well.
Make your own Manjaro image - by flatulent_piney - 11-07-2020, 03:30 AM
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,109 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,328 07-31-2021, 04:44 AM
Last Post: jiyong
  Video : How to install Armbian Reforged and set it up on PineBookPro / Gaming image NicoD-SBC 0 2,720 11-23-2020, 12:09 PM
Last Post: NicoD-SBC
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,017 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,378 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 2,871 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 9,612 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 57,466 07-11-2020, 09:01 PM
Last Post: xmixahlx
  full disk encryption with luks on manjaro xfce limxr 48 66,669 07-09-2020, 07:27 AM
Last Post: JtR
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 7,809 06-23-2020, 12:41 AM
Last Post: pljanson
