Vision Processing
(12-10-2015, 09:03 AM)codetheweb Wrote: I'm not sure if this is better posted in hardware or software, but...
How does the Pine A compare with the Raspberry Pi in terms of vision processing?  I tried a simple OpenCV blob tracking example with the Pi, and it gave an unacceptable framerate of 5-7 FPS.  Can we expect a better framerate with the Pine (20-30 FPS)?
Note, in reading the datasheet for the pine64 camera (https://drive.google.com/file/d/0B0cEs0l...yUWYw/view), I discovered that the camera can only do about 15 fps at full resolution.  If you don't need full resolution, then it get a higher frame rate (720p at 30fps and VGA at 60fps).  Note, this is just for the camera itself, and not any bottlenecks due to communication or processing.
Vision Processing - by codetheweb - 12-10-2015, 09:03 AM
RE: Vision Processing - by taros - 12-15-2015, 03:37 AM
RE: Vision Processing - by rubenk - 03-01-2016, 05:37 PM
RE: Vision Processing - by patrickhwood - 03-01-2016, 09:28 PM
RE: Vision Processing - by rubenk - 03-01-2016, 10:00 PM
RE: Vision Processing - by patrickhwood - 03-01-2016, 11:50 PM
RE: Vision Processing - by MichaelMeissner - 03-02-2016, 06:50 AM
RE: Vision Processing - by rubenk - 03-03-2016, 07:30 AM
RE: Vision Processing - by NWUK - 03-06-2016, 04:29 PM
RE: Vision Processing - by Scientist - 11-18-2017, 02:23 AM
