Recover data from crashed emmc
>Should mounting mmcblk2 work with defaults?
Not the WHOLE device, you have to mount partitions (eg, /dev/mmcblk1p1)
You can run fdisk on an image, then mount with the appropriate offset
eg sudo mount someimage existing-empty-mount-point -o loop,offset NNNN(K) (and maybe) -t type
testdisk if its really screwed up, you can run testdisk on an image
If fdisk seems to be "right" then run a fsck on PARTITION maybe more than once (until it ends without error)
Recover data from crashed emmc - by S265 - 10-12-2020, 04:38 AM
RE: Recover data from crashed emmc - by ab1jx - 10-20-2020, 05:09 PM
RE: Recover data from crashed emmc - by lewellyn - 10-20-2020, 05:43 PM
RE: Recover data from crashed emmc - by wdt - 10-20-2020, 08:17 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,923 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 296 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,855 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,348 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,656 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 814 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,039 10-10-2022, 06:22 AM
Last Post: maxjrh
  6/22 run of PBPs - is reimaging eMMC with new OS possible still? elitegamercody 29 10,841 10-04-2022, 07:55 PM
  Debian emmc installer db579 6 2,805 08-23-2022, 06:13 AM
Last Post: db579
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 8,790 08-18-2022, 11:26 PM
Last Post: calinb
