noob with non booting rock64 4g
(10-12-2020, 01:58 PM)john72carter Wrote:
(10-11-2020, 06:36 PM)Rocklobster Wrote: Can't be certain but I think the Rock64 struggles with newer versions of Linux 5x. I'm using the following version
____  ___  ____ _  ____  _  _
|  _ \ / _ \ / ___| |/ / /_ | || |
| |_) | | | | |  | ' / '_ \| || |_
|  _ <| |_| | |___| . \ (_) |__  _|
|_| \_\\___/ \____|_|\_\___/  |_|
Welcome to Debian Buster with Armbian Linux 4.4.192-rockchip64
System load:  0.01 0.02 0.00  Up time:      12 days
Memory usage:  14 % of 3988MB  IP:            192.168.0.206
CPU temp:      47°C
Usage of /:    7% of 58G
[ General system configuration (beta): armbian-config ]
See if you grab the above version as I can confirm it works.
thanks
more of the same im afraid :-)
the lack of output from hdmi doesn't help.
So connected up to HDMI you are seeing nothing. Make sure you have a good quality HDMI cable connected to the monitor and the board before you power up the Rock64
The only other thing to check I can think of is a bad SD card or a flaky power supply. Try substituting both and see if that helps.
noob with non booting rock64 4g - by john72carter - 10-10-2020, 01:27 PM
RE: noob with non booting rock64 4g - by Rocklobster - 10-14-2020, 07:35 PM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 1 112 03-18-2024, 06:56 AM
Last Post: diederik
  Rock64 bricked shawwwn 7 5,448 03-17-2024, 12:22 PM
Last Post: dmitrymyadzelets
  Rock64 won't boot luminosity7 10 3,863 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 254 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,769 04-29-2023, 04:24 AM
Last Post: newestssd
  OpenWRT on the Rock64 CanadianBacon 12 7,790 04-24-2023, 12:40 PM
Last Post: arunkhan
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,395 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 1,973 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 703 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 904 10-07-2022, 07:50 PM
Last Post: rookie_267
