NAS/fileserver project—RP64 in 1U ATX/ITX case (comments welcome!)
Hi, how is your interesting project going?
Regarding the mounting of the RP64 board to the ITXATX case: Why not make an adapter plate (metal or 3d printed), screw the RP64 to that and then screw the adapter plate to the case?
Regarding the PCIe card: There are not just static riser cards but also plenty of riser "cables" available, so it should be no problem getting this done.
Another more difficult aspect would be access to ports from the outside. You could attach also extensions here (e.g. for the microSD slot or the USB ports) but it will probably not work with everything. Also connecting the buttons and LEDs could turn out to be a challenge.
One more thing that would be interesting: Which heatsink/fan are you planning to use for the SoC?
RE: NAS/fileserver project—RP64 in 1U ATX/ITX case (comments welcome!) - by kuleszdl - 01-09-2021, 08:16 PM
  Anyone require a apple-sleek NAS case, w/ ample passive cooling & mutliple ssds? dairymilkbatman 0 333 01-19-2024, 02:17 PM
Last Post: dairymilkbatman
  3D Printed 2 SSD Vertical NAS Case tenox 1 2,174 12-19-2021, 01:30 PM
Last Post: CounterPillow
  [Turorial] NAS Using A Recycled 1U Proliant Case ColPanic_ 1 2,783 06-02-2021, 12:51 AM
Last Post: LMM
  Ideas to use extra space in NAS case? _hg_ 1 3,301 10-04-2020, 11:42 PM
Last Post: zer0sig
Star Detailed NAS Case assembly (ameriDroid) Luke 15 24,695 10-04-2020, 01:04 AM
Last Post: Humid Stylus
  Project Idea - RockPro San version User 18962 3 5,626 08-10-2020, 10:57 AM
Last Post: aleksei
