Email addresses in Claws for Manjaro-Arm
After a few problems, some of which were/are user caused, my PBP seems to be working good.  However, when I installed an email app or program there were several choices: Claws, which is included with Manjaro; and Thunderbird, which is used on my main computer.  Using Thunderbird, I am able to use almost any email server and use almost any email address that server allows.  Claws, on the other hand, includes at least one email address (username@manjaro-arm).  When I try to send a small file from the desktop computer (the main computer) to the PBP, I get a notice that the message can not be sent and gives a failure code.  My question: Is there, or should there be, some designation at the end of the @manjaro-arm like .org or .net or .com?  Wondering because it would be easy to use email to transfer short files between the two computers until I learn enough to set up some other way to connect the two computers.
Thank you,
James Good
Email addresses in Claws for Manjaro-Arm - by James Good - 07-26-2020, 11:44 AM
  New User use PineBookPro default OS Manjaro clessard 0 1,545 07-02-2022, 09:01 AM
Last Post: clessard
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 1,558 05-23-2022, 08:49 AM
Last Post: 98cwitr
  Java on Manjaro ARM Pinebook Pro gulagpyromaniac 3 3,787 05-25-2021, 11:05 AM
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,828 02-02-2021, 12:13 AM
Last Post: PineSupporter
  brand new manjaro PBP - pacman PGP import failure shindagger 0 2,054 06-18-2020, 07:19 AM
Last Post: shindagger
  no url in registration email for accessing support pinoosh 0 1,711 12-26-2016, 12:46 PM
Last Post: pinoosh
