sudden ethernet failure
Hardware: Pine64 A64 512MB
OS:  Armbian Buster 20.02.1 (kernel 5.4)
After months of running steady through multiple reboots and sudden power failures, all my boards suddenly lost eth0; all simultaneously; all while powered on and otherwise running without issue. No, I was not logged in and doing things with the system at the time. My router alerted me when the connections dropped out.
Things I tried (and failed):
  • different ports on ethernet switch
  • power cycling (hard reboot)
  • hook up monitor and keyboard and investigate
Investigation discovered no eth0 device. dmesg reports no driver.
lshw is not present on system so I cannot probe hardware and maybe get driver working with modprobe.
So I reflashed the OS and ... no network. dmesg reports no driver.
So I flashed a differnt OS -- Armbian Bionic 20.05.2 (kernel 5.4) -- and ... no network. dmesg output below.
dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
dwmac-sun8i 1c30000.ethernet: PTP uses main clock
dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 2001 (expect 0)
dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
dwmac-sun8i 1c30000.ethernet: COE Type 2
dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
dwmac-sun8i 1c30000.ethernet: Normal descriptors
dwmac-sun8i 1c30000.ethernet: Chain mode enabled
dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
dwmac-sun8i 1c30000.ethernet eth0: stmmac_dvr_remove: removing driver
dwmac-sun8i: probe of 1c30000.ethernet failed with error -14
Any ideas or assistance appreciated.
sudden ethernet failure - by Paraplegic Racehorse - 07-16-2020, 04:12 PM
RE: sudden ethernet failure - by KC9UDX - 07-16-2020, 06:16 PM
RE: sudden ethernet failure - by KC9UDX - 07-17-2020, 10:06 PM
RE: sudden ethernet failure - by zer0sig - 07-20-2020, 05:09 PM
RE: sudden ethernet failure - by lot378 - 08-30-2020, 04:09 PM
RE: sudden ethernet failure - by lot378 - 08-31-2020, 02:41 AM
RE: sudden ethernet failure - by lot378 - 08-31-2020, 08:36 AM
RE: sudden ethernet failure - by KC9UDX - 08-31-2020, 01:59 PM
RE: sudden ethernet failure - by antonagestam - 10-29-2021, 12:53 AM
RE: sudden ethernet failure - by DVS_Dee - 11-10-2021, 05:05 PM
  Disappearing Ethernet port goathunter 3 5,695 05-22-2019, 09:00 AM
Last Post: goathunter
