I/O errors from SD card slot? (Manjaro, kernel 5.7)
I'm having the exact same problem. Whenever I try to write to the SD card, the operation fails and dmesg gets filled with messages like:
[  343.365760] blk_update_request: I/O error, dev mmcblk1, sector 15138815 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
[  343.365785] Buffer I/O error on dev mmcblk1, logical block 1892351, lost async page write
[  343.367655] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 5 prio class 0
[  343.367668] Buffer I/O error on dev mmcblk1, logical block 0, lost async page write
[  343.367725] Buffer I/O error on dev mmcblk1, logical block 1, lost async page write
[  343.367742] Buffer I/O error on dev mmcblk1, logical block 2, lost async page write
[  343.367757] Buffer I/O error on dev mmcblk1, logical block 3, lost async page write
Likewise, the SD card works perfectly in other computers, and this issue only appeared right after I installed the latest linux-pinebookpro and uboot-pinebookpro packages from Manjaro (versions 5.7.19 and 2020.10, respectively). Previously the system had mrfixit2001's Debian image and I did not experience this issue.
I also found another thread where someone seems to be experiencing the same issue after installing Manjaro. It seems likely that it's either a kernel issue or an issue in U-Boot.
RE: I/O errors from SD card slot? (Manjaro, kernel 5.7) - by 25519 - 10-28-2020, 01:16 AM
  Manjaro versions bad and good gilwood 0 234 02-12-2024, 05:03 PM
Last Post: gilwood
  uboot wont boot to SD card after upgrade jbradley419 7 761 01-19-2024, 02:29 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,175 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 660 12-13-2023, 08:17 PM
Last Post: trillobite
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,147 09-19-2023, 08:48 AM
Last Post: dachalife
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 317,732 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 1,453 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 1,975 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 562 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 3,144 02-06-2023, 09:11 AM
