Suggestions for improvement
After some experimentation in my own fork, then returning to regular Mobian, I've come up with some suggestions for how to improve Mobian which I don't think belongs on the bug tracker, at least not without some discussion first.
1. Replace Fractal with the flathub version of Nheko. This brings E2E support but it doesn't fit in the general theme of Phosh. The version from the repo segfaults and I've been unable to make my own builds work any better.
2. Copy over the udev rules from PostmarketOS to create EG25 symlinks in /dev/. I don't know if it's useful to anyone else but I feel more comfortable using the symlinks than trying to remember which ttyUSB[0-3] is which.
3. Periodic wakeup from deep sleep (perhaps we have an RTC we can trigger?) to refresh notifications from email and such. Even something like 30 minutes of sleep and a few seconds of activity with the display turned off before going back into deep sleep would help for me to keep track of my emails. Might not be frequent enough for instant messaging but I'll leave that up for discussion. Ideally this would be configurable.
4. GPSd. This is a big question, do we want it or not? Many desktop applications use it but they have questionable value on such a small screen anyway. Not sure if it breaks the new ModemManager style location access but the GPSd tools "gpsmon" and "cgps" have both helped be debug bad GPS reception.
5. Side arrow keys on either side of the space bar. I've already implemented this in my fork (where I also adapted the improved terminal keyboard to get the full screen width) but some people might find them annoying.
6. Have a preloaded whitelist for applications which should scale automatically. For instance, Maps is pretty useless without scaling turned on. When upstream Phoc/Phosh figures out how to solve this we can just remove the whitelist.
7. I've found that doing a renice of the "phoc", "phosh", "squeekboard" and "calls" processes I get what feels like a much more responsive system. I haven't found anything it interferes with yet but I also haven't had time to set it up to be automatically applied after boot.
8. Call recording. This was one of my pet peeves with Android, being designed specifically to prevent call recording. Mobian doesn't have those restrictions but since I had a huge pile of work to do dropped in my lap about 2 weeks ago I haven't had much time to figure out how the audio routing is done. Ideally I'd record the two sound streams going in and out of the modem directly as separate channels to a stereo file, which would make it easy to import the audio into Audacity if I'd ever need it. This might be better suited upstream in the calls app rather than in our local version, but I'd need to know how audio routing is implemented first.
9. Easy Anbox setup. I know this is a controversial issue but there needs to be a more streamlined setup process. I could throw together a quick script to do it semi-automatically but it's pretty useless if it doesn't result in more eyes on the Android app support. There are still a couple of Android apps which I need until we have suitable replacements, notably Slack and Signal with support for calls. Even with Anbox installed the Android apps have issues with audio. I don't know what to do about this, all I know is that I can't ignore the issue anymore.
10. VAAPI for hardware accelerated video decoding. I was working on this until 2 weeks ago and hit a brick wall when the Aarch64 GNU assembler refused to cooperate with me. The code doesn't look that hard to understand so I still want to take a shot at it but with a different approach; instead of porting to Aarch64 I could port it over to generic C code. The reasoning here is that i think it was made in assembler to begin with because it was supposed to run on very low end ARMv7 chips where every instruction counts. Our A53 cores a a lot beefier than that and while I'm not saying we can waste cycles, I think we can leave it up to the C compiler to optimize the code better than I can. Any help with this is very welcome.
Some of these are fairly straight forward changes while others are longer term projects. Please comment on these even if you disagree with me, feedback on things like these is important. I will open GitLab issues for the features people want and go back to the drawing board for the rest of them.
Suggestions for improvement - by Djhg2000 - 07-10-2020, 09:57 AM
RE: Suggestions for improvement - by a-wai - 07-10-2020, 04:32 PM
RE: Suggestions for improvement - by wibble - 07-11-2020, 03:20 PM
RE: Suggestions for improvement - by a-wai - 07-12-2020, 03:07 AM
