Login screen issue.
(07-07-2020, 08:40 AM)LinuXchoicE Wrote: Any ideas on how to fix this, and can I even get to a terminal to work some magic on the backend?
Yes, you should be able to. Use Ctrl + Alt + F(2-7) to get to a TTY, where you can login and work through the terminal. You should be able to look at any system messages to see why KDE isn't loading, too.
Login screen issue. - by LinuXchoicE - 07-07-2020, 08:40 AM
RE: Login screen issue. - by tophneal - 07-07-2020, 08:54 AM
RE: Login screen issue. - by LinuXchoicE - 07-07-2020, 09:06 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 293 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 2,945 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,004 04-01-2023, 07:55 AM
Last Post: hacknix
  Newbie with immediate issue jasonumd 1 976 03-04-2023, 05:59 PM
Last Post: hacknix
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 1,982 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,083 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,740 05-09-2022, 05:53 AM
Last Post: gerstavros
  suckless surf on arch linux pinebook pro scrolling issue gehn5 0 975 04-16-2022, 07:41 PM
Last Post: gehn5
Question USB-C Video Out Issue dev 2 1,856 02-08-2022, 07:28 PM
Last Post: dev
  Putting my screen on TV S265 6 4,734 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
