Camera support progress
#21
(07-07-2020, 01:35 PM)jwestman Wrote: This is not working for me, on my Braveheart PinePhone. Here's the dmesg output:
mobian ~$ dmesg | grep -E "(csi|ov5640)"
[    1.425837] dovdd-csi: Bringing 3300000uV into 1800000-1800000uV
[    1.428194] avdd-csi: Bringing 2900000uV into 2800000-2800000uV
[    1.430261] dvdd-csi: Bringing 700000uV into 1800000-1800000uV
[    4.172849] i2c-gpio i2c-csi: using lines 141 (SDA) and 140 (SCL)
[    8.972532] sun6i-csi 1cb0000.csi: creating ov5640 3-004c:0 -> sun6i-csi:0 link
[    8.979971] sun6i-csi 1cb0000.csi: creating gc2145 3-003c:0 -> sun6i-csi:0 link
[    9.918406] ov5640 3-004c: ov5640_init_slave_id: failed with -6
[  11.526450] ov5640 3-004c: ov5640_init_slave_id: failed with -6
[  39.310878] ov5640 3-004c: ov5640_init_slave_id: failed with -6
[  40.475398] ov5640 3-004c: ov5640_init_slave_id: failed with -6
Camera shows a test pattern when I run it, indicating that no cameras are detected at all.
I flashed Mobian to my SD card from the mobian-pinephone-20200707 image, then upgraded using "sudo apt upgrade" (only one package, pinephone-tweaks, was updated), then restarted.
 I also have a Brave Heart,   I am still running from the SD card.
I downloaded the 20200707 nightly build,  then installed to SD using etcher. (re-sized to max on 32gb San Disk card using 'disks' )
  ( The default setting is  'auto-update'  but I do not think it did an update.)
The camera does  'just work'  using GUI on my phone.  It is low resolution, but pictures are not bad.
  Any chance your privacy switches were changed ?  I always look for the simplest answers first, then, work up from there.
Good Luck, BC
Camera support progress - by a-wai - 07-06-2020, 10:06 AM
RE: Camera support progress - by aancel - 07-06-2020, 10:54 AM
RE: Camera support progress - by bingo600 - 07-06-2020, 12:15 PM
RE: Camera support progress - by chris_02 - 07-06-2020, 02:11 PM
RE: Camera support progress - by a-wai - 07-06-2020, 03:03 PM
RE: Camera support progress - by chris_02 - 07-06-2020, 03:36 PM
RE: Camera support progress - by jjs - 07-06-2020, 03:32 PM
RE: Camera support progress - by a-wai - 07-06-2020, 03:50 PM
RE: Camera support progress - by chris_02 - 07-06-2020, 03:58 PM
RE: Camera support progress - by Ersatz - 07-06-2020, 03:51 PM
RE: Camera support progress - by Luke - 07-06-2020, 04:05 PM
RE: Camera support progress - by bendavey - 07-06-2020, 04:59 PM
RE: Camera support progress - by devrtz - 07-07-2020, 03:03 AM
RE: Camera support progress - by arturo2bodegas - 07-06-2020, 08:07 PM
RE: Camera support progress - by cefre00 - 07-07-2020, 01:37 AM
RE: Camera support progress - by e-minguez - 07-07-2020, 03:03 AM
RE: Camera support progress - by Luke - 07-07-2020, 04:13 AM
RE: Camera support progress - by bingo600 - 07-07-2020, 09:13 AM
RE: Camera support progress - by Kamzzy - 07-07-2020, 01:32 PM
RE: Camera support progress - by jwestman - 07-07-2020, 01:35 PM
RE: Camera support progress - by bcnaz - 07-07-2020, 09:27 PM
RE: Camera support progress - by aancel - 07-08-2020, 01:59 PM
RE: Camera support progress - by aancel - 07-08-2020, 02:17 PM
RE: Camera support progress - by a-wai - 07-09-2020, 02:24 AM
RE: Camera support progress - by aancel - 07-09-2020, 03:08 PM
RE: Camera support progress - by a-wai - 07-13-2020, 05:28 AM
RE: Camera support progress - by paju1986 - 07-13-2020, 05:41 AM
RE: Camera support progress - by a-wai - 07-13-2020, 05:56 AM
RE: Camera support progress - by aancel - 07-14-2020, 01:23 AM
RE: Camera support progress - by a-wai - 07-14-2020, 03:03 AM
RE: Camera support progress - by aancel - 07-14-2020, 03:34 AM
RE: Camera support progress - by a-wai - 07-14-2020, 04:03 AM
RE: Camera support progress - by aancel - 07-15-2020, 10:23 AM
RE: Camera support progress - by a-wai - 07-17-2020, 06:56 AM
RE: Camera support progress - by aancel - 07-17-2020, 05:56 PM
RE: Camera support progress - by ivanB1975 - 07-18-2020, 03:50 PM
RE: Camera support progress - by aancel - 07-22-2020, 12:46 PM
RE: Camera support progress - by chris_02 - 07-22-2020, 01:23 PM
RE: Camera support progress - by puffchumpy - 07-18-2020, 08:58 AM
RE: Camera support progress - by arturo2bodegas - 07-22-2020, 06:04 PM
RE: Camera support progress - by a-wai - 07-22-2020, 06:18 PM
RE: Camera support progress - by chris_02 - 07-23-2020, 05:55 AM
RE: Camera support progress - by hiimtye - 08-01-2020, 07:32 PM
RE: Camera support progress - by daniel - 08-10-2020, 10:39 AM
RE: Camera support progress - by fernando_c_m - 08-10-2020, 11:17 AM
RE: Camera support progress - by natasha - 08-10-2020, 12:56 PM
RE: Camera support progress - by fernando_c_m - 08-10-2020, 01:41 PM
RE: Camera support progress - by natasha - 08-10-2020, 02:27 PM
RE: Camera support progress - by fernando_c_m - 08-11-2020, 12:34 AM
RE: Camera support progress - by spaetz - 08-11-2020, 07:28 AM
RE: Camera support progress - by natasha - 08-11-2020, 01:24 PM
RE: Camera support progress - by fishbowlkraken - 08-11-2020, 11:39 PM
RE: Camera support progress - by natasha - 08-12-2020, 12:44 PM
RE: Camera support progress - by a-wai - 08-13-2020, 08:46 AM
RE: Camera support progress - by PainPhone - 08-14-2020, 08:53 AM
RE: Camera support progress - by natasha - 08-14-2020, 09:40 AM
RE: Camera support progress - by PainPhone - 08-10-2020, 01:17 PM
RE: Camera support progress - by Baggypants - 08-12-2020, 12:49 PM
RE: Camera support progress - by daniel - 08-13-2020, 05:42 PM
RE: Camera support progress - by FOSSagent0 - 08-14-2020, 12:07 AM
RE: Camera support progress - by natasha - 08-14-2020, 06:09 AM
RE: Camera support progress - by daniel - 08-14-2020, 08:32 PM
RE: Camera support progress - by fishbowlkraken - 08-15-2020, 03:37 PM
RE: Camera support progress - by root - 08-16-2020, 04:18 PM
RE: Camera support progress - by natasha - 08-17-2020, 12:46 PM
RE: Camera support progress - by bcnaz - 08-16-2020, 04:31 PM
RE: Camera support progress - by chris_02 - 08-16-2020, 05:12 PM
RE: Camera support progress - by fernando_c_m - 08-17-2020, 12:27 AM
RE: Camera support progress - by bcnaz - 08-17-2020, 08:43 AM
RE: Camera support progress - by henkdieter - 08-17-2020, 11:26 AM
RE: Camera support progress - by chris_02 - 08-17-2020, 12:34 PM
RE: Camera support progress - by bcnaz - 08-17-2020, 07:49 PM
RE: Camera support progress - by bcnaz - 08-18-2020, 02:46 PM
RE: Camera support progress - by wi_badger - 08-18-2020, 04:05 AM
  The program doesn`t detect the camera blag0rag 2 219 02-15-2024, 08:03 PM
  Could not initialize OpenGL support jojuma 1 264 01-17-2024, 05:57 PM
Last Post: anonymous
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 1,136 07-17-2023, 01:49 AM
Last Post: junelung
  Trying the camera switch on my PinePhone gilwood 5 3,213 04-02-2022, 12:54 PM
Last Post: jhasler
  Bluetooth audio support? Zebulon Walton 5 3,545 02-28-2022, 08:59 AM
  Mainline MMS Support?? tyha 2 1,999 01-06-2022, 03:25 PM
Last Post: bcnaz
  mobian, pinephone camera, and megapixels dawg161 32 28,459 05-01-2021, 02:34 PM
Last Post: NormandC
  no camera,streaming after update rvh 0 1,569 03-21-2021, 08:02 AM
Last Post: rvh
  PSA: Transition in progress - don't update ! a-wai 46 45,284 11-20-2020, 10:37 AM
Last Post: Gribouille
  Progress (and Thank you) Zoomzit 0 1,635 11-12-2020, 01:14 PM
Last Post: Zoomzit
