Not booting after latest update
To disable auto-brightness:
gsettings set org.gnome.settings-daemon.plugins.power ambient-enabled false
To set a correct brightness value (as root)
echo 400 > /sys/class/backlight/backlight/brightness
I'm working on a new kernel version which should (hopefully) get the brightness scale right...
(06-26-2020, 08:33 AM)Boern Wrote: from a chroot, that just made everything worse and it wouldn't boot at all. But running it from within a fresh mobian-pinephone-20200615.img.gz installation worked.
yes, I wouldn't have tried that from a chroot, only from a running system (whether it runs from SD or eMMC doesn't matter)
Not booting after latest update - by Boern - 06-25-2020, 03:13 PM
RE: Not booting after latest update - by a-wai - 06-26-2020, 02:12 AM
RE: Not booting after latest update - by Boern - 06-26-2020, 08:33 AM
RE: Not booting after latest update - by a-wai - 06-26-2020, 09:19 AM
  No volume control after latest updates Zebulon Walton 19 7,134 09-08-2023, 08:28 AM
Last Post: jessencan
  how to update mobian over tor vusra 13 6,883 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 1,227 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,333 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 4,211 02-26-2023, 01:01 PM
Last Post: anonymous
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,297 11-28-2022, 03:30 PM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 8,818 10-14-2022, 05:38 PM
Last Post: Krafter
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 2,652 09-27-2022, 08:41 AM
Last Post: Katsujinken
  Wifi issue since last update and held back updates goku499 11 5,306 09-21-2022, 02:39 PM
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,858 09-11-2022, 09:24 PM
