Screen refresh delay with kernel errors
#21
(06-29-2020, 02:45 PM)shawnanastasio Wrote:
(06-29-2020, 02:35 PM)bchenlee609 Wrote: Hello,
I used your new patch, so hopefully have done the APPEND modification properly.
Output of dmesg | grep command listed below:
    [0.000000] Kernel command line: initrd=/initramfs-linux.img console=tty1 console=ttyS2,1500000 root=LABEL=ROOT_MNJRO rw rootwait video=eDP-1:1920x1080@60 video=HDMI-A-1:1920x1080@60 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash analogix_dp.enable_psr=0
Any advice would be appreciated. If not, seems like this change will roll out on a wider scale eventually too, can wait until then. Was just trying to use this as a learning experience too Smile
Thanks!
-B
Your kernel command line is correct, so the issue must be that you either didn't apply the patch correctly or didn't install/boot the new kernel correctly. I personally just used the kernel's own build system to build and install the kernel, so I'm not super familiar with Manjaro's makepkg method. According to mtnygard's post it seems the patch needs to be applied after `makepkg -o` and before `makepkg -e`, then you use `pacman -U` to install the newly built kernel.
If possible, could you try modifying the kernel's LOCALVERSION string to contain something unique? You should be able to edit the .config file after the `makepkg -o` step with a text editor to do this. This will allow you to see if the you're successfully booting the patched kernel by running `uname -r` and seeing if the new LOCALVERSION appears.
Thanks for your last reply! Life gets in the way tinkering with this laptop unfortunately.
May I ask for some clarification? Which .config file am i editing after the 'makepkg -o' step?
And once in there, how do I modify the LOCALVERSION string?
Sorry if these are silly questions, this is all new for me.
I wish there were a way to check at this point whether or not I applied your patch correctly (without modifying the kernel localversion string)
I'm assuming this is not possible?
Thanks again!
-B
RE: Screen refresh delay with kernel errors - by bchenlee609 - 07-07-2020, 10:20 PM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 283 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 2,935 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 1,982 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,725 01-22-2023, 10:05 PM
Last Post: rfm83
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 2,827 01-22-2023, 09:55 PM
Last Post: rfm83
  minimal kernel .config? alchemist 5 5,887 08-15-2022, 06:28 PM
Last Post: svmhdvn
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 1,974 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,075 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,731 05-09-2022, 05:53 AM
Last Post: gerstavros
  PinebookPro Build Errors mexsudo 3 2,901 01-30-2022, 08:36 AM
Last Post: mexsudo
