[split] Change password from external media
I'll try to make it simple, assuming a SD boot with manjaro
lsblk -a ,,, your SD is /, probably mmcblk1p2 ,, ie blk1
Probably emmc is blk2, root filesystem on that /dev/mmcblk2p2
It will be more easy since SD card is 32G and emmc is 64G, so size makes it clear
Start filemanager dolphin, left column click emmc drive (note size to be sure)
If there is a still a distro installed, the regular directories will be there,
bin, boot, home, etc, opt , root, sbin, usr and so on
click etc (to change to that directory), press f4 to get command window, resize larger
double check
df -h (is emmc mounted? size shows)
pwd (where am I? /mountpoint/something/etc/)
sudo cp shadow shadow.bak
sudo nano shadow
Do editing mentioned 3 posts above
Shutdown, remove SD card, reboot
RE: [split] Change password from external media - by wdt - 07-23-2020, 02:42 PM
  oem password iwm 8 2,412 02-19-2023, 07:35 PM
Last Post: iwm
  Issues with External Display After Recent Update reundo 0 1,378 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 2,209 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  My pbp is a sleek, black, flat brick, and won't boot from any kind of media rotwang 15 13,866 08-24-2021, 04:25 PM
Last Post: bkenn
  Graphical login hanging after password entry mhill8 2 3,368 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  External DVD/CD MIchael 22 22,139 03-07-2021, 03:49 PM
Last Post: ab1jx
  External Monitor Recommendations SteveSquatch 1 1,808 02-17-2021, 08:23 AM
Last Post: Arwen
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,759 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  [split] U-Boot with NVMe support, keyboard & display working as400 83 82,567 01-27-2021, 12:48 AM
Last Post: as400
  MAC address change user0258 2 3,497 09-16-2020, 01:12 PM
Last Post: user0258
