USB OTG Boot
I agree that choosing 2 type A receptacles is more user-friendly. But since it's almost impossible to provide more than 10W through micro USB and as you already said shitty chargers and cables lying around will be used many Pine64 users will have to learn the hard way that they need a powered USB hub to connect external devices (like it's the case with Raspberry Pi often). Something that will add to the total costs significantly.
I would believe the Remix Mini makers (also based on A64 with the same connector choices) chose a 3A/5V PSU with barrel plug for a reason and I don't believe the consumption numbers provided in the wiki are close to realistic: http://wiki.pine64.org/index.php/Main_Page#Power_Usage
USB OTG Boot - by devilsclaw - 01-09-2016, 09:53 PM
RE: USB OTG Boot - by tllim - 01-09-2016, 10:59 PM
RE: USB OTG Boot - by Andrew2 - 01-10-2016, 05:45 AM
RE: USB OTG Boot - by tllim - 01-10-2016, 12:45 PM
RE: USB OTG Boot - by devilsclaw - 01-10-2016, 01:46 PM
RE: USB OTG Boot - by tllim - 01-10-2016, 01:57 PM
RE: USB OTG Boot - by Andrew2 - 01-10-2016, 02:43 PM
RE: USB OTG Boot - by ssvb - 01-10-2016, 07:40 AM
RE: USB OTG Boot - by Andrew2 - 01-10-2016, 07:48 AM
RE: USB OTG Boot - by ssvb - 01-10-2016, 08:00 AM
RE: USB OTG Boot - by Andrew2 - 01-10-2016, 08:17 AM
RE: USB OTG Boot - by ssvb - 01-10-2016, 08:19 AM
RE: USB OTG Boot - by ssvb - 01-10-2016, 02:45 PM
RE: USB OTG Boot - by tllim - 01-10-2016, 03:29 PM
RE: USB OTG Boot - by ssvb - 01-10-2016, 04:47 PM
RE: USB OTG Boot - by tllim - 01-10-2016, 06:04 PM
RE: USB OTG Boot - by devilsclaw - 01-10-2016, 07:20 PM
RE: USB OTG Boot - by ssvb - 01-10-2016, 09:56 PM
RE: USB OTG Boot - by janjwerner - 01-22-2016, 08:39 PM
RE: USB OTG Boot - by tllim - 01-23-2016, 11:17 AM
RE: USB OTG Boot - by ssvb - 01-23-2016, 02:27 AM
RE: USB OTG Boot - by Quintus23M - 01-24-2016, 01:51 PM
RE: USB OTG Boot - by tllim - 01-24-2016, 02:04 PM
RE: USB OTG Boot - by kenjiru - 10-24-2016, 04:27 AM
RE: USB OTG Boot - by Learnincurve - 02-24-2017, 04:15 AM
RE: USB OTG Boot - by CaptainZalo - 03-01-2017, 03:22 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,169 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Secure boot & OTP efuse program devangpanchal90 0 2,596 05-25-2018, 01:59 AM
Last Post: devangpanchal90
  boot process for pine a64 awaysu 1 4,402 01-24-2018, 05:09 AM
Last Post: xalius
  Can't boot headless after running update_uboot.sh Borglesnorgle Williams 2 4,263 08-17-2017, 04:08 AM
Last Post: Borglesnorgle Williams
Exclamation Pine A64 Plus Fails to Boot grobbs 35 41,161 06-28-2017, 08:53 AM
Last Post: sarav_sara
  Boot issues: What todo when you muck up your FSTAB file Dagremote 1 3,768 04-16-2017, 10:28 PM
Last Post: pfeerick
Question Pine64 cannot boot jamiechang917 6 9,649 04-16-2017, 10:21 PM
Last Post: pfeerick
  U-Boot for A64 git longsleep 38 68,904 03-21-2017, 01:59 PM
Last Post: longsleep
  OpenWRT supports ARMv8 - arm64, u-boot problem? rgdonato 4 6,760 03-20-2017, 03:59 PM
Last Post: rgdonato
  How to boot alternative kernel image with u-boot? zhouer 3 6,810 06-27-2016, 04:15 AM
Last Post: ssvb
