Rock64 - Simple Bare-Metal Example
I wrote a simple Bare-Metal example for the Rock64.
It just sends a few strings over the UART interface and if a special char will be received, the program resets the Rock64.
The main entry point of the program (written in Assembler):
#include <asm.h>
IMPORT_C(kern_main)
.text
ENTRY(_start)
   mrs x0, SCTLR_EL1
   and x0, x0, #0xFFFFFFFFFFFFFFFC
   msr SCTLR_EL1, x0
   mrs x0, SCTLR_EL2
   msr SCTLR_EL2, x0
   mrs x0, MPIDR_EL1
   and x0, x0, #0x3
   cmp x0, #0
   beq L1
L0:
   wfe
   b L0
L1:
   ldr x0, =_kern_stack_s
   mov sp, x0
   b kern_main
L2:
   wfe
   b L2
.end
It's a minimal setup. It just disables the MMU and the Alignment checks.
Then it reads the processor ID and let only CPU0 run the C main entry point (kern_main).
The C main entry point:
#include <dev/cru.h>
#include <dev/uart.h>
void kern_main(void)
   int c;
   uart_init();
   uart_puts("Pine64 Rock64\r\n");
   uart_puts("Press 'r' to reset the board!\r\n");
   do {
       c = uart_getc();
   } while (c != 'r');
   uart_puts("Resetting...\r\n");
   cru_reset();
   while (1)
Should be self explaining.
There is also as very simple UART driver and the CRU driver for resetting the board.
The code includes a very minimal C String library.Only GCC for AArch64 is needed.
To start the application, U-Boot is needed.
I have attached the full code.
The code is also on my GitHub page available.
Edit:
Oops! There is a bug in the attached archive.
Simple change the following line in the file start.S...
to..
ldr x0, =_kern_stack_e
.gz   bare-metal.tar.gz (Size: 4.47 KB / Downloads: 471)
/* Beware of bugs in the above code; I have only proved it correct, not tried it */
 Original quote by Donald E. Knuth
Rock64 - Simple Bare-Metal Example - by krjdev - 06-05-2020, 07:27 AM
Information Manual: Howto cross-compile Upstream U-Boot for rock64 rock7 3 8,183 04-15-2020, 05:09 PM
Last Post: rock7
Thumbs Up A guide for how I made RetroPie, RetroArch, and EmulationStation Work on the Rock64 Mrfixit2001 4 16,170 12-17-2018, 03:52 AM
Last Post: va88
  Using the Movidius NCS with rock64 markjay 0 4,379 07-02-2018, 09:51 AM
Last Post: markjay
