Installing DietPie on Rock64 and set 1280x1024 resolution
Thanks in advance for taking the time of reading this and possibly trying to help.
I recently got a 1 GB ROCK64, and I want to install DietPi on it. I have a 32 GB Class 10 micro SD card, a Realtek RTL8188EU Wi-FI USB dongle and a wireless keyboard + mouse combo, so up to this point I assume I'm properly equipped for the installation. The thing is I don't have any 1080p TVs or monitors (I live in Venezuela), but I do have an HDMI to VGA converter, which I'm planning to use with a 1280x1024 monitor. It also supports other resolutions, such as 800x600.
I already tried flashing the image to the micro SD card using Etcher, and the ROCK64 seems to boot up but no image appears on screen. I presume that it is booting up because the mouse turns on when I power the ROCK64.
Although I'm a Linux user, I'm completely new to the SBC world. Please, do keep that in mind.
I want to know how to change the resolution so I can proceed with the installation. I already tried Googling this issue, and even though there is comprehensive information on the subject, I couldn't find a specific solution for the ROCK64. I don't know which file I have to edit to change the resolution of the output.
I presume the issue is exclusively the output resolution, but I can't be sure. I hope someone more experienced can tell me what possibly could be wrong.
I have to add that all 3 lights of the board turn on and stay like that. I haven't tried leaving the board on for a while.
Disclaimer: I already posted this on the DietPi forum, but I haven't received an answer from them after a day. I figured that a ROCK64 forum was more likely to help me.
What do you see when you boot the board. Are you being asked to log in. Have you tried to log in via ssh from another computer.
(05-25-2020, 05:53 AM)Rocklobster Wrote: What do you see when you boot the board. Are you being asked to log in. Have you tried to log in via ssh from another computer.
Nothing appears on screen. I'll try today to leave the board on for a good 20 minutes to see if anything comes on screen. I haven't tried to use ssh, but I'll do that as well.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 148 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,352 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 333 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 609 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 606 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,353 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,316 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 590 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 649 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,294 12-07-2022, 08:22 PM
Last Post: luminosity7
