bluetooth rock64 problem
Question
hello,
I had to set up my Rock64 a few days ago because the SD card had unfortunately died.
As always, I first installed a new SD card with the image "Armbian_20.02.1_Rock64_buster_current_5.4.20". Everything great. Only my bluetooth stick does not want to run.
I don't have a desktop version, only access via SSH
The stick is recognized, as before. Here are a few system information:
root@rock64:~# lsusb
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0451:16a8 Texas Instruments, Inc.
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@rock64:~#
root@rock64:~# dmesg | grep -i bluetooth
[34669.643396] Bluetooth: Core ver 2.22
[34669.643482] Bluetooth: HCI device and connection manager initialized
[34669.643498] Bluetooth: HCI socket layer initialized
[34669.643506] Bluetooth: L2CAP socket layer initialized
[34669.643522] Bluetooth: SCO socket layer initialized
root@rock64:~#
root@rock64:~# hcitool scan
Device is not available: No such device
root@rock64:~#
root@rock64:~# hcitool dev
Devices:
root@rock64:~#
Why is the stick not recognized with hcitool?
What else can I do?
What is missing ?
cu Deta
I wonder if you boot without the dongle plugged in and plug it in after the boot completes
(05-01-2020, 11:45 AM)Rocklobster Wrote: I wonder if you boot without the dongle plugged in and plug it in after the boot completes
ok
have now switched off the Rock64, pulled the dongle and switched on.
root@rock:~# sudo service bluetooth status
● bluetooth.service - Bluetooth service
  Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
  Active: inactive (dead)
    Docs: man:bluetoothd(8)
root@rock:~# sudo /etc/init.d/bluetooth start
[ ok ] Starting bluetooth (via systemctl): bluetooth.service.
root@rock:~# sudo /etc/init.d/bluetooth status
Mai 05 14:41:56 rock systemd[1]: Condition check resulted in Bluetooth service being skipped.
root@rock:~# hcitool dev
Devices:
root@rock:~#
Now I put the dongle back in.
   Active: active (running) since Tue 2020-05-05 14:44:18 CEST; 2s ago
 Main PID: 12311 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4746)
   Memory: 2.4M
   CGroup: /system.slice/bluetooth.service
           └─12311 /usr/lib/bluetooth/bluetoothd
Mai 05 14:44:18 rock systemd[1]: Starting Bluetooth service...
Mai 05 14:44:18 rock bluetoothd[12311]: Bluetooth daemon 5.50
Mai 05 14:44:18 rock systemd[1]: Started Bluetooth service.
Mai 05 14:44:18 rock bluetoothd[12311]: Starting SDP server
Mai 05 14:44:19 rock bluetoothd[12311]: kernel lacks bnep-protocol support
Mai 05 14:44:19 rock bluetoothd[12311]: System does not support network plugin
Mai 05 14:44:19 rock bluetoothd[12311]: Bluetooth management interface 1.14 initialized
Devices:
root@rock:~#
The Same...
Mh i think that is the Problem
root@rock:~# sudo modprobe btusb
modprobe: FATAL: Module btusb not found in directory /lib/modules/5.4.32-rockchip64
root@rock:~#
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 151 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,361 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 335 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 609 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,383 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,471 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,361 12-07-2022, 08:22 PM
Last Post: luminosity7
