Anyone have CPU Speed widget on Manjaro 20.04?
I am loving Manjaro 20.04 on Pinebook Pro, really working well for me. I have had very few issues and most have been solved easily.
One issue that I have not figured out and have not been able to find in the forum with a search: I miss the CPU speed indicator/selector widget that was in the Debian install.
Has anyone got that to work under Manjaro?
Thanks, Tim
Lucko666
"Just say Angry to smilies.
(04-16-2020, 11:29 AM)tim2@timshome.com Wrote: I am loving Manjaro 20.04 on Pinebook Pro, really working well for me. I have had very few issues and most have been solved easily.
Thanks, Tim
Which DE are you using? If XFCE, you could probably use whichever widget the MATE install was using. (I'm guessing system-monitor) and there's several for KDE. Whichever you need/choose, you can likely find them available in the AUR. (You can turn it on in the preferences of pamac.)
(04-16-2020, 01:34 PM)tophneal Wrote:
(04-16-2020, 11:29 AM)tim2@timshome.com Wrote: I am using KDE, I looked in AUR and in repositories, didn't find it. Nor in "add widgets." Conky serving purpose but not as elegantly!
Thanks, Tim
Lucko666
Thanks, Tim
This plasmoid looks to be pretty close to the widget in the MATE taskbar.
https://store.kde.org/p/998908/
[quote pid='64265' dateline='1587070697']
I got this to work but I really don't think it replaces the Mate one. That one allowed you to control the scheme, like "conservative" "power saver" etc. This  one only shows speed.
[/quote]
Thanks for the suggestion, however. For now I can get detailed results using a module of Conky that I can install with Conky Manager, gives speed and load on all cores. Although it doesn't allow me to change the scheme, it shows that the computer is actively managing the CPU speed well.
[/quote]
Lucko666
  Manjaro Sway Theme Broken Eighty8 1 168 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,607 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 215 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,917 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,979 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 292 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 746 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,913 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,853 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 709 08-18-2023, 02:06 AM
Last Post: juliamenendez
