How to boot from the SD card and install to eMMC?
Hi, wanting to try another OS (the new Manjaro) I downloaded the emmc installler image and flashed it to a 16GB SanDisk microSD with the PINE64 INSTALLER utility.
However, my Pinebook Pro refuses to boot from the SD card as long as the internal eMMC drive is swithced on. After switching it off with the little toggle under the hood, I can boot from SD card but then... How to install to the internal drive?
Can anyone point me to some clear instructions either on the wiki or these forums? For a noob it's completely confusing...
Thanks! Smile
(03-16-2020, 07:01 AM)ravanh Wrote: Hi, wanting to try another OS (the new Manjaro) I downloaded the emmc installler image and flashed it to a 16GB SanDisk microSD with the PINE64I INSTALLER utility.
Thanks! Smile
I found a post saying to update the PC with the Mrfixit script first. I did this, but I still cannot boot from the SD card that I loaded Manjaro to. I'm looking for a solution as well.
(03-18-2020, 09:34 AM)pb1051 Wrote: I found a post saying to update the PC with the Mrfixit script first. I did this, but I still cannot boot from the SD card that I loaded Manjaro to. I'm looking for a solution as well.
Which Manjaro image are you trying to boot? Do you recall if the script updated your uboot (it would've been towards the tail end of the scripts output, last thing I think.)
If not, you can try updating it manually using the files from the repo.
https://github.com/mrfixit2001/updates_r...filesystem
Download the idbloader, trust, and uboot .imgs to you PBP, navigate to them in a terminal and run these commands:
dd if=idbloader.img of=/dev/youremmc bs=32k seek=1 conv=fsync
dd if=uboot.img of=/dev/youremmc bs=64k seek=128 conv=fsync
dd if=trust.img of=youremmc bs=64k seek=192 conv=fsync
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 638 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  eMMC empty? bluedemon382 0 740 07-19-2023, 06:29 AM
Last Post: bluedemon382
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,128 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,567 05-24-2023, 02:45 AM
Last Post: draintroup
  USB adapter to eMMC module not recognized danril 0 1,285 11-25-2022, 04:16 AM
Last Post: danril
  PBP Debian 11 GRUB install error zlth 2 1,894 11-18-2022, 07:42 AM
Last Post: zlth
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,547 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,686 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,043 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,215 10-23-2020, 01:30 AM
Last Post: HotChocolate
