chromium keyring password change or remove
Hello PBP Posters.
I've had my pbp ansi for about a week.  Currently I have one issue to resolve.  I logged in to Chromium before I changed the key pad to english US. Now, unintentionally, I have a symbol for the UK pound in my keyring password for Chromium.  There is no equivalent in the english US layout.  Can someone provide directions on changing or eliminating this keyring for chromium?   So far pretty good with this device.  Chromium was glitchy and firefox would crash instantly. A mrfixit update help a lot. Firefox now works fine.
Thanks in advance!
Would purging chromium and then reinstalling work?
$ rm ~/.config/google-chrome/Default/Login
(01-25-2020, 03:24 PM)Veraendert Wrote: $ rm ~/.config/google-chrome/Default/Login
As a newbie please clarify.  Run this command in the terminal starting with $ to remove this log-in feature? Or set to default?
$ means run as user, no sudo, no root
That command should remove the keyring.
But i just realized that would be for Chrome, not Chromium.
Making that path...
~/.config/chromium/Default/Login
The folder is correct, I'm not sure about the file, as I disabled the keyring on my install! Wink
(01-27-2020, 02:09 AM)Veraendert Wrote: $ means run as user, no sudo, no root
Hello Veraendert,
I ran this command as posted in the terminal.  Substituting Chromium for Google-Chrome as well but can up with file not found. If you can think of something else please post.
Sorry, i also disable the keyring. I hate Chromium, i only use it if everything else fails.
$ rm ~/.config/chromium/Default/'Login Data'
(01-29-2020, 06:45 AM)Veraendert Wrote: Sorry, i also disable the keyring. I hate Chromium, i only use it if everything else fails.
Well, Running this script did not resolve my issue.  Thanks for trying.  I just deleted chromium completely using the package manager. I may reinstall justtot have a backup to firefox which is working fine.  Thanks again!
Sorry it didn't work out. If you use Plasma you could give Falkon a try. It's based on Chromium's engine but i trust it more than anything coming from Google directly.
  oem password iwm 8 2,378 02-19-2023, 07:35 PM
Last Post: iwm
  Trouble with keyring IHaveALinuxPhone 1 1,407 04-30-2022, 08:37 PM
Last Post: TRS-80
  I have two different versions of Chromium on my Pro! Nobot 2 2,636 06-01-2021, 02:34 PM
Last Post: Nobot
  Chromium Dino game is slow/glitchy stozi 0 1,331 04-21-2021, 08:18 AM
Last Post: stozi
  Graphical login hanging after password entry mhill8 2 3,334 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  Netflix, Amazon Prime Video, and Chromium. Nobot 13 18,277 03-12-2021, 10:46 AM
Last Post: spikerguy
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,748 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  Issues with chromium-docker PVD 4 6,385 12-17-2020, 10:11 PM
Last Post: warehouses
Photo Remove activity manager bar on right side of screen - plasma kde motezart 3 4,524 10-20-2020, 10:36 AM
Last Post: motezart
  MAC address change user0258 2 3,486 09-16-2020, 01:12 PM
Last Post: user0258
