Kali Linux for Pinebook Pro
#91
Guessing it has something to do with u-boot-update? Can check when I've fixed my PBP...
On that subject, up until now I installed Kali with:
sudo dd if=kali-linux-2022.1-pinebook-pro-xfce-arm64.img of=/dev/mmcblk1 status=progress conv=fsync
For some reason the PBP won't boot (it has a working NVME drive)
I would try following this. I was able to get Kali installed on my PBP. Only issue i'm having is the Wifi is not running.
https://www.kali.org/docs/arm/pinebook-pro/
$ xzcat kali-linux-2022.3-pinebook-pro-arm64.img.xz | sudo dd of=/dev/mmcblk1 bs=4M status=progress
Took about 10min to install.
This post has the wifi fix.  Kali wifi is still broken as of right now.
https://forum.pine64.org/showthread.php?...#pid112493
Has anyone gotten the image to work well? I find that mine boots it does a goofy display glitch looking thing (like used to happen to VGP vidcards without proper drivers), but only for a moment, then it seems to boot okay. But it seems to reboot at random and it doesn't always come up at all.
it doesn't get happy
it doesn't get sad
it just runs programs
I’ve been running Kali with one of the new Pinebooks and it has been usable so far.
Had to fix the wifi & I get the same glitch screen on boot up (I think when it’s looking for the video card), but other than that it has been doing good.
Using it daily at work: some of the security software, Firefox, Thunderbird and to make reports (writer & calc) with Libreoffice. I have it running from the eMMC and the sd card as storage with U-Boot & kernel: 5.18.0-kali5-arm64.
I haven’t had the restart problem, but I did have to get a decent sdcard for it to be reliably recognized.
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
Still have the reboot issue, no problem here Smile
But I do miss Zenmap in Kali. For some reason the ARM version is no longer supported/maintained. I've seen the howto's but they don't seem to fix the issue
Interest in Kali on pbp seems to have dropped to zero?
Still using mine daily at work & everything is fine; nothing really to post about.
Compiled a new kernel for it and added some blue-tooth earbuds, about it.
Just an update, for those wondering about progress; Kali is still working fine on the PBP (04/10/2023),
stock Kernel 6.0.0-kali5-arm6, custom kernels are also working well; Daily driver ready, been using it since last year, without any real problems, with daily updates (that haven’t broken anything yet) .
Tempted to go towboot & reinstall but same here
  Debian on Pinebook Pro u974615 7 971 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,516 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 332 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,125 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,186 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,422 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,211 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,229 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,462 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,562 08-07-2023, 01:12 PM
Last Post: myself600
