Upgrade Debian kernel on a SD/SATA drive boot combo.
I currently have:
Linux taz 4.4.132-1075-rockchip-ayufan-ga83beded8524 #1 SMP Thu Jul 26 08:22:22 UTC 2018 aarch64 GNU/Linux
Debian 9
Root is on sda2
Boot is on the sd card (/dev/mmcblk0p*)
I am trying to upgrade it to a later release so I can get fan control (I have no pwm device). I've used aptitude to jump to 5.4.0-rc1-1120 but I don't seem to get it to reboot to it. I see a number of files on /boot (on the SD card) and I'm not sure if I need to change any of them (the efi is not something I've figured out yet).
So you have a new kernel installed but it doesn't boot? Do you have any logs via serial console or on screen?
(12-03-2019, 05:15 PM)xalius Wrote: So you have a new kernel installed but it doesn't boot? Do you have any logs via serial console or on screen?
Not yet, I need to hook up the USB dongle to it again. The syslog and the dmesg don't say anything.
Finally got the console setup (and boy does that prompt go by fast, need to fix that later). Here's what I'm seeing:
Scanning mmc 1:7...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
2059 bytes read in 23 ms (86.9 KiB/s)
select kernel
1:      kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524
2:      org-kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524
3:      org-kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524
4:      kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524-memtest
Enter choice:
Okay I see a problem, there's no 5.5 in the list. I've update an extlinux.conf. But there are 2, one under /boot/efi/extlinux and the other under /boot/extlinux. So my guess if neither is correct and that the new funky efi stuff needs to have more done before it can see the 5.5 Kernel.
Any pointer?
You need to get the new kernel back on the SDcard to boot it. Something like
sudo mount /dev/mmcblk0p7 /mnt/
sudo rsync -ax --delete /boot/ /mnt/boot/
ps - good luck with 5.4 - be ready to manually edit your SDcard to revert to 4.4 if your luck is anything like mine, see this thread.
(12-11-2019, 01:23 PM)dukla2000 Wrote: You need to get the new kernel back on the SDcard to boot it. Something like
What could possibly go wrong ... ;-)
I'll set up a second SD and try that out.
(12-11-2019, 11:40 PM)linuxha Wrote: I'll set up a second SD and try that out.
You don't need a second SDcard: if it fails then you just need another PC you can edit the /boot/extlinux/extlinux.conf file on. Either add a efaultt line or make sure the 4.4 section is the first one.
e.g. with the file below I boot 4.4.197
$ cat /boot/extlinux/extlinux.conf
timeout 10
menu title select kernel
default kernel-4.4.197
label kernel-4.4.202
   kernel /boot/vmlinuz-4.4.202-1237-rockchip-ayufan-gfd4492386213
   initrd /boot/initrd.img-4.4.202-1237-rockchip-ayufan-gfd4492386213
   devicetreedir /boot/dtbs/4.4.202-1237-rockchip-ayufan-gfd4492386213
   append rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4
label kernel-4.4.197
   kernel /boot/vmlinuz-4.4.197-1236-rockchip-ayufan-g30faab37e339
   initrd /boot/initrd.img-4.4.197-1236-rockchip-ayufan-g30faab37e339
   devicetreedir /boot/dtbs/4.4.197-1236-rockchip-ayufan-g30faab37e339
  Boot/Shutdown on timer captainmorgan 8 6,088 11-01-2023, 12:08 PM
Last Post: Nikolay_Po
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 840 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,475 08-16-2023, 01:34 AM
Last Post: varac
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 1,126 06-16-2023, 10:54 AM
Last Post: CounterPillow
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 562 04-23-2023, 11:02 PM
Last Post: Thisone
Question nand-sata-install on RAID-1 array ARMandHammer 1 884 02-12-2023, 03:10 AM
Last Post: igorp
  RockPro64 boot questions misterc 3 1,596 01-13-2023, 06:21 PM
Last Post: misterc
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,351 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  hello i want to drive an edp screen with my rockpro64 hannescam 0 761 10-20-2022, 01:22 PM
Last Post: hannescam
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 1,839 05-08-2022, 03:26 PM
Last Post: paralin1
