5.3 kernel support?
what's the status on kernel developement/support for the latest 5.x kernel?
I have a rock64 (version 1?) and I'm wondering if there are still plans to support it, or if the board is more/less being "given up on" at this point...
(10-17-2019, 04:36 PM)csrf Wrote: what's the status on kernel developement/support for the latest 5.x kernel?
Working well  with arch linux arm. I'm using them headless as network appliances. I don't know if there are video issues. The network stack and USB3 performance is RADICALLY IMPROVED, compared to earlier kernels.
[root@honeypot3 ~]# cat /proc/version
Linux version 5.3.6-1-ARCH (builduser@leming) (gcc version 8.3.0 (GCC)) #1 SMP Sat Oct 12 17:02:44 UTC 2019
thanks for the info, however, I'm wondering when the mainline kernel will more generally be supported by other distros, as I prefer to go with a Debian-based system. Is this an issue where rockchip hasn't progressed in releasing an updated kernel???
(10-18-2019, 02:17 PM)csrf Wrote: thanks for the info, however, I'm wondering when the mainline kernel will more generally be supported by other distros, as I prefer to go with a Debian-based system.  Is this an issue where rockchip hasn't progressed in releasing an updated kernel???
No idea about that.
+1 bump for Debian based distro support.
Confirm had good success with arch earlier.
Please share your dotconfig, or any patches to the kernel you needed to make!
  Linux 5.15 Kernel - openSuse mark1250 0 1,275 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 6,739 10-22-2021, 05:45 AM
Last Post: kwinz
  1024x600 resolution support monte 1 2,757 03-14-2021, 11:32 PM
Last Post: monte
  Debian kernel stuck at 4.4.167 Enig123 5 5,610 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,233 08-31-2020, 01:41 AM
Last Post: as365n4
  Encryption support rockfun 1 2,925 06-10-2020, 08:27 AM
Last Post: rockfun
  mainline kernel sound support Openwrt lucize 2 4,048 05-01-2020, 05:09 PM
Last Post: PakoSt
  Help troubleshooting kernel panic gabrielfin 3 4,632 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 2,007 02-05-2020, 10:58 PM
Last Post: dkebler
  Any advantages to using the mainline kernel dkebler 0 2,113 11-16-2019, 12:17 PM
Last Post: dkebler
