Can anyone run Boinc on Pine models?
I thinking about buying ~3-6 Rock or Pine, and launching Boninc  on it(most medicine and biology. Rosetta and so). Butt is complicated, because not much info. I want the most effective solution. Sorry for my English
(09-09-2019, 02:06 PM)MarijusR Wrote: I thinking about buying ~3-6 Rock or Pine, and launching Boninc  on it(most medicine and biology. Rosetta and so). Butt is complicated, because not much info. I want the most effective solution. Sorry for my English
Can you paste exact commands you want tested, the more info the better, and I'll try running it for you
if you install Boinc not on android, then boinccmd --run_benchmarks. On android Boinc hawe interface.
(09-10-2019, 03:27 PM)MarijusR Wrote: if you install Boinc not on android, then boinccmd --run_benchmarks. On android Boinc hawe interface.
On a rockpro64 I got the following results:
Sep 10 22:59:30 rockpro64 boinc[20034]: 10-Sep-2019 22:59:30 [---] Running CPU benchmarks
Sep 10 22:59:30 rockpro64 boinc[20034]: 10-Sep-2019 22:59:30 [---] Suspending computation - CPU benchmarks in progress
Sep 10 23:00:01 rockpro64 boinc[20034]: 10-Sep-2019 23:00:01 [---] Benchmark results:
Sep 10 23:00:01 rockpro64 boinc[20034]: 10-Sep-2019 23:00:01 [---]    Number of CPUs: 6
Sep 10 23:00:01 rockpro64 boinc[20034]: 10-Sep-2019 23:00:01 [---]    1989 floating point MIPS (Whetstone) per CPU
Sep 10 23:00:01 rockpro64 boinc[20034]: 10-Sep-2019 23:00:01 [---]    49520 integer MIPS (Dhrystone) per CPU
Sep 10 23:00:02 rockpro64 boinc[20034]: 10-Sep-2019 23:00:02 [---] Resuming computation
I've previously run ffmpeg tests and the rockpro64 took about 5 minutes, and the rock64 took 15 minutes.
Thanks. Can You run it on Rock64 or Pine?
(09-11-2019, 02:37 AM)MarijusR Wrote: Thanks. Can You run it on Rock64 or Pine?
I don't have a pine64-lts board but on the rock64 I get the following results:
Sep 11 18:53:12 shed-rock64 boinc[575]: 11-Sep-2019 18:53:12 [---] Benchmark results:
Sep 11 18:53:12 shed-rock64 boinc[575]: 11-Sep-2019 18:53:12 [---]    Number of CPUs: 4
Sep 11 18:53:12 shed-rock64 boinc[575]: 11-Sep-2019 18:53:12 [---]    1374 floating point MIPS (Whetstone) per CPU
Sep 11 18:53:12 shed-rock64 boinc[575]: 11-Sep-2019 18:53:12 [---]    35805 integer MIPS (Dhrystone) per CPU
Sep 11 18:53:13 shed-rock64 boinc[575]: 11-Sep-2019 18:53:13 [---] Resuming computation
Important are network.
Meybe in future connect pine not only ethernet. RS-232, direct gpio etc?
faster network are important with parallel lib
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,619 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 608 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 3,939 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 5,981 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,342 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,506 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,777 12-06-2020, 03:53 PM
Last Post: junkyj753
  Node Red on the Pine DonFL 0 2,775 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,247 12-02-2019, 09:36 PM
Last Post: netHolio
  NetBSD for Pine A64(+) Luke 3 6,735 10-05-2019, 11:04 PM
Last Post: mrgtwentythree
