Need Sollution : Screen Problem and says the Error "Out of Range" on the display
have a Pine64 2GB which i am used to use with my TV with the Android for TV OS.. but i planned to use my pine64 device to another room where i have a very old model screen which has a VGA input... i connected them with VGA converter, but it didn't work, after changing and using different converter it alwasy say "Out of Signal".. i used the same converter and connected my Pine64 with my new TV and it worked even with the HDMI to VGA converter.. Then i connected my laptop with the old monitor and it even worked but only when i connected the Pine64 Device it says the problem..
after googling it i kinda found that probably it's because of the screen resolution(my screen is square, maybe 15 inch monitor).. i tried to change resolution from monitor, but there is nothing to change actually..  i think, there could be some way to change the resolution(if the problem is bcz of the resolution) by changing some config files on the image file...
ii tried with different img files (Android TV 7.1, Android TV 7.0 , LibreELEC-KODI, Xenial Mate & Q4OS) and only  with LibreELEC-KODI the display came without any problem.. Hope someone could guide me to fix the problem and i would be able to use my Pine64 device with the very old monitor... given i am also sharing the photo of my monitor that could make u the idea to find the solution... Thnx in advance and forgive me if i ask really some noob question..   Smile  Smile
[Image: YEGXSZt]
https://imgur.com/YEGXSZt
[Image: f8xSbDU]
https://imgur.com/f8xSbDU
[Image: HHDzPPk]
https://imgur.com/HHDzPPk
[Image: qmbA89k]
https://imgur.com/qmbA89k
[Image: aHJH9tZ]
https://imgur.com/aHJH9tZ
today i tried with different img files (Android TV 7.1, Android TV 7.0 , LibreELEC-KODI, Xenial Mate & Q4OS) and only with LibreELEC-KODI the display came without any problem.. As i told you that i am very amateur with this board, i really need someones guide to solve the problem..
Hello hunterzonecss,
Unfortunately the HDMI driver in the BSP kernel only supports a few resolutions. So a lot of the images really only work with monitors that are 1080p or 720p.
I think the mainline kernel supports more resolutions now. You might want to try the Arch Linux mainline image:
http://wiki.pine64.org/index.php/Pine_A6...Linux_XFCE
Question External storage problem for pine64 Dani6102 4 1,720 08-22-2023, 08:36 AM
Last Post: gulshan212
  Jack connector problem pinebug 0 1,533 11-10-2022, 01:46 PM
Last Post: pinebug
  lcd touch screen and hdmi output moreaujacky 2 5,047 10-24-2018, 07:24 AM
Last Post: lisanke
  No HDMI Display need help with correct uEnv.txt settings dkebler 7 10,509 01-11-2018, 02:52 PM
Last Post: dkebler
Rainbow Pine64 + waveshare display? iPhyse 4 6,930 10-12-2016, 04:43 PM
Last Post: hamzahbondok
  problem connecting to Pine 64 store stephen fleming 2 4,355 09-24-2016, 08:57 PM
Last Post: stephen fleming
  TV Screen Edge woes: 2 Fixes NexusDude 10 38,267 09-05-2016, 03:09 PM
Last Post: Toriless
  7" Screen abasel 2 4,436 07-27-2016, 06:43 AM
Last Post: Ghost
  Other Screen Options? kikootwo 3 5,543 07-10-2016, 01:18 PM
Last Post: Ghost
  Problem making SD card Tam Dl 17 20,288 06-19-2016, 07:48 PM
Last Post: pfeerick
