ROCK64 Kernel compilation problem
I had a problem compiling the rock64 kernel(https://github.com/rock64-linux?tab=repositories),
Buiding kernel and u-boot image: build/mk-kernel.sh rk3328-rock64(build/mk-uboot.sh rk3328-rock64)
The current uboot partial compilation is OK。
 Building kernel for rk3328-rock64 board!
 Using rockchip_linux_defconfig
# configuration written to .config
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
  CHK     include/generated/timeconst.h
  CHK     include/generated/bounds.h
  CHK     include/generated/asm-offsets.h
  CALL    scripts/checksyscalls.sh
make[1]: 'include/generated/vdso-offsets.h' is up to date.
  CHK     include/generated/compile.h
  CC      arch/arm64/kernel/topology.o
  CC      block/elevator.o
  CC      crypto/ablk_helper.o
arch/arm64/kernel/topology.c: In function ‘parse_cluster’:
arch/arm64/kernel/topology.c:133:40: warning: ‘%d’ directive output may be truncated writing between 1 and 10 bytes into a region of size 3 [-Wformat-truncation=]
error, forbidden warning: topology.c:133
scripts/Makefile.build:258: recipe for target 'arch/arm64/kernel/topology.o' failed
make[1]: *** [arch/arm64/kernel/topology.o] Error 1
Makefile:983: recipe for target 'arch/arm64/kernel' failed
make: *** [arch/arm64/kernel] Error 2
make: *** Waiting for unfinished jobs....
  GZIP    kernel/config_data.gz
  CC      kernel/relay.o
crypto/ablk_helper.c: In function ‘ablk_init’:
crypto/ablk_helper.c:144:49: warning: ‘%s’ directive output may be truncated writing up to 63 bytes into a region of size 55 [-Wformat-truncation=]
error, forbidden warning: ablk_helper.c:144
scripts/Makefile.build:258: recipe for target 'crypto/ablk_helper.o' failed
make[1]: *** [crypto/ablk_helper.o] Error 1
Makefile:983: recipe for target 'crypto' failed
make: *** [crypto] Error 2
  CC      drivers/cpufreq/rockchip-cpufreq.o
block/elevator.c: In function ‘elv_register’:
block/elevator.c:839:14: warning: ‘snprintf’ output may be truncated before the last format character [-Wformat-truncation=]
error, forbidden warning: elevator.c:839
scripts/Makefile.build:258: recipe for target 'block/elevator.o' failed
make[1]: *** [block/elevator.o] Error 1
Makefile:983: recipe for target 'block' failed
make: *** [block] Error 2
kernel/relay.c: In function ‘relay_create_buf_file’:
kernel/relay.c:420:35: warning: ‘snprintf’ output may be truncated before the last format character [-Wformat-truncation=]
error, forbidden warning: relay.c:420
scripts/Makefile.build:258: recipe for target 'kernel/relay.o' failed
make[1]: *** [kernel/relay.o] Error 1
Makefile:983: recipe for target 'kernel' failed
make: *** [kernel] Error 2
^CTraceback (most recent call last):
  File "./scripts/gcc-wrapper.py", line 102, in <module>
    scripts/Makefile.build:403: recipe for target 'drivers/firmware' failed
scripts/Makefile.modbuiltin:54: recipe for target 'drivers/gpu/arm/mali400/ump' failed
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 134 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,326 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 323 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 594 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 594 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,232 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,281 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 582 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 632 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 32,920 12-07-2022, 08:22 PM
Last Post: luminosity7
