USB drive powered off after reboot
I've got an SSD connected to my rock64 via USB3 and booting from it without issues.
$ lsusb
Bus 005 Device 002: ID 7825:a2a4
The only problem is when I reboot the system. The USB is powering off, but won't get powered on again. As a result the system won't boot. Checked on latest bionic-minimal, stretch-minimal, openmediavault, dietpi. When I boot from the sdcard the drive gets powered on at first and running fine. Then again after reboot the USB is powered off and system boots from sdcard with the USB drive powered off.
An older HDD doesn't have this issue and power is delivered to the USB after reboot so looks like problems with this specific enclosure.
Run a test on RPI3 and after reboot the drive gets powered on.
Do you have some ideas what I could look for / test to nail it down?
Thank you
(12-20-2018, 11:34 AM)huberttrz Wrote: Hello,
$ lsusb
Thank you
I've tried with the magic SysRq key (s+u+b) and the boards resets with the drive being powered on all the time (so there is a workaround). To me it looks like something is happening during os shutdown which makes the USB drive be powered off (while it shouldn't). Seems to be kernel related but I guess my level of knowledge won't allow me to find the cause.
  External hard drive problem k8Va 17 22,580 03-09-2021, 02:31 PM
Last Post: calinb
Sad Rock64 crash randomly during usb 3 copy with RAID1 drive phalae 24 35,277 09-14-2020, 10:48 AM
Last Post: BrownLuther007
  USB 3.0 hard drive write speed increase tip on Ubuntu 18.04 Wizardknight 3 6,888 05-26-2019, 10:28 PM
Last Post: Wizardknight
Question HDD filesystem corruption at reboot / poweroff (DietPi) WrongWorld 1 2,926 02-11-2019, 04:00 PM
Last Post: WrongWorld
  Spontaneous Reboot during scp with Ubuntu bionic 0.7.8-1061 perniciouscaffeine 0 1,889 10-16-2018, 05:34 PM
Last Post: perniciouscaffeine
  Freeze/reboot/errors when compiling - unable to make - reproducible and not isolated jovval 2 3,893 10-02-2018, 08:10 AM
Last Post: jovval
  Rock64 - Stuck when do the soft reboot ramprasad 10 13,862 06-21-2018, 01:16 AM
Last Post: pfeerick
  HDD gets not detected after reboot pascal51882 8 8,848 04-19-2018, 04:12 PM
Last Post: k8Va
  boot emmc, trying to access SD Drive E.G 0 1,624 04-13-2018, 09:05 PM
Last Post: E.G
  Root FS on usb3 drive eloranta 7 7,241 12-18-2017, 10:43 PM
Last Post: eloranta
