Can't connect to wifi on a Rock64
I'm trying to set up a Rock64 to connect to wifi using a Panda PAU09 USB wifi adapter.  The adapter is mounted in a fixed location, and when connected to my laptop running Ubuntu Bionic, I am able to easily connect to my own wifi network, as well as my school's secure network and their guest network using NetworkManager.  However, when I connect the adapter to the Rock64, I am unable to connect to any wifi networks, in spite of seeing them listed when I do a network scan.  I have tried this using Armbian Stretch and Bionic images, and also using ayufan's Bionic image.  When using nmcli to bring up the connection, I usually receive the error message "The Wi-Fi network could not be found".  However, scanning for networks usually shows the network I am attempting to connect to with good signal strength.  Other times, the connection will actually "succeed" but I won't be able to communicate over it and then the connection just goes down within seconds.
Any ideas on how I could make this work?
(12-18-2018, 07:14 PM)SuperSaiyanCaleb Wrote: I'm trying to set up a Rock64 to connect to wifi using a Panda PAU09 USB wifi adapter.  The adapter is mounted in a fixed location, and when connected to my laptop running Ubuntu Bionic, I am able to easily connect to my own wifi network, as well as my school's secure network and their guest network using NetworkManager.  However, when I connect the adapter to the Rock64, I am unable to connect to any wifi networks, in spite of seeing them listed when I do a network scan.  I have tried this using Armbian Stretch and Bionic images, and also using ayufan's Bionic image.  When using nmcli to bring up the connection, I usually receive the error message "The Wi-Fi network could not be found".  However, scanning for networks usually shows the network I am attempting to connect to with good signal strength.  Other times, the connection will actually "succeed" but I won't be able to communicate over it and then the connection just goes down within seconds.
Quick google of your adaptor and it seems to be an 802.11ac device which aren't included in the linux kernel. This means most if not all distros don't include drivers for it.
At a quick glance I wasn't able to find linux drivers from the manufacturer's website, nor the chipset it uses
802.11n, actually.  According to this, it makes use of the Ralink RT5572.  The fact that NetworkManager detects it and is able to scan for networks with it suggested to me that drivers are indeed included in the default configurations of the images I tried, but I'm all ears if there's something else I should install.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 134 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,328 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 323 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 594 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 594 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,233 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,463 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 582 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 632 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 32,938 12-07-2022, 08:22 PM
Last Post: luminosity7
