slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64)
support for slarm64 for rockpro64 development boards (aarch64 unofficial port slackware)
the system can be assembled as armhf and aarch64, assemblies are made under aarch64
links:
         site: fail.pp.ua
         forum: linuxquestions
         development: https://gitlab.com/sndwvs/images_build_kit
first release:
         README.TXT
update, DDR Version 1.14 20180803
slack-current-aarch64-miniroot_29Sep18-4.4.162-rockpro64-build-20181126.img.tar.xz
slack-current-aarch64-miniroot_29Sep18-4.4.162-rockpro64-build-20181126.img.tar.xz.md5
slack-current-aarch64-xfce_29Sep18-4.4.162-rockpro64-build-20181126.img.tar.xz
slack-current-aarch64-xfce_29Sep18-4.4.162-rockpro64-build-20181126.img.tar.xz.md5
I installed os on my pro and would like to know how to connect to wifi
tried in supplicant
network={
   ssid="Your SSID Here"
   psk="YourPresharedKeyHere"
also variuos variations of
ip link set wlan0 up
    iwconfig wlan0 essid your_essid key your_key
It dettects wireless adaptor and if I iwcinfig does show  network availble but cant get it to connect its a WPA2
wpa_gui throws an error
also if posible is it posible to fix screen overscan?
looks nice just really not able to connect to wifi my ignorance is quite a fallback could you point me the way to connect to a wpa2 wireless network?
(11-27-2018, 03:24 PM)NightCrawler504 Wrote: I installed os on my pro and would like to know how to connect to wifi
tried in supplicant
network={
1. in the file /etc/wpa_supplicant.conf register
network={
2. in the /etc/rc.d/rc.inet1.conf file, uncomment the lines:
IFNAME[4]="wlan0"
USE_DHCP[4]="yes"
WLAN_WPA[4]="wpa_supplicant"
3. restart the /etc/rc.d/rc.inet1 service as:
/etc/rc.d/rc.inet1 restart
or
/etc/rc.d/rc.inet1 wlan0_up
Quote:also if posible is it posible to fix screen overscan?
it's not quite clear how this manifests itself, I pretend that I need in the settings of XFCE -> window manager (optional) -> effects -> enable effects
Added Slackware Aarch64 Miniroot (ROCKPro64) 20181126 on Wiki and PINE64 Installer.
Added Slackware Aarch64 XFCE (ROCKPro64) 20181126 on Wiki and PINE64 Installer.
Did the above throws me:
wlan0 information: 'Any ESSID'
Error for wireless request "Set Nickname" (8B1C) :
Set failed on device wlan0: operation not supported
Successfully initialized wpa_supplicant
ioctl[SIOCSIWENCODEEXT] : Invalid arguement
Blablabla
Timed out
Dhcp exited
(11-28-2018, 05:27 PM)NightCrawler504 Wrote: Did the above throws me:
Blablabla
Timed out
Dhcp exited
try the options with the driver (uncomment):
WLAN_WPADRIVER[4]="nl80211"
[quote pid='42819' dateline='1543450259']
[/quote]
Error persists have no idea what's wrong guess I'll just wait some one gets it right ask them to upload a suplicant and inet1 file, I'm using wpa2 on aes, tried 3 wireless USB adapters and its difficult to post and extract errors without internet since for some reason usb 3 port seems to not pick up wireless adapter nor USB memory card, thanks anyway looks like a solid project hope it becomes noob friendly Big Grin
there is an updated kernel, with sdio0 (wifi) enabled and pmic fixed
download kernel-*-rk3399-4.4.166-aarch64-1mara.txz
kernel update:
upgradepkg kernel-*-rk3399-4.4.166-aarch64-1mara.txz
Quick question... does the designware i2s audio driver (modprobe dw_hdmi_i2s_audio) work properly in that 4.4.166?
Because all ayufan kernels higher than 4.4.138 have serious HDMI/i2s audio issues, so I've been stuck at 4.4.138-1100 since I first got this board.
There's dmesg errors about "i2s: fail to clear" or something like that, haven't tried to solve it in a month+.
Then again, I actually thought that might have been because of ayufan's DTB and the frequencies in it.
Is someone able to confirm dw_hdmi_i2s_audio works ok?
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 465 03-25-2024, 12:12 PM
  RK3399 PCIe enumeration jhadd 0 268 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 712 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,612 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,316 08-16-2023, 01:34 AM
Last Post: varac
  How to enable CoreSight ETM trace on RockPro64 shpark 0 581 05-21-2023, 11:34 PM
Last Post: shpark
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 1,371 05-13-2023, 12:01 AM
Last Post: swan
  Rockpro64 Dead on arrival? quixoticgeek 1 946 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,575 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,651 01-03-2023, 06:53 PM
Last Post: raph
