Install Playstore on Android 7.1.2
How to install PlayStore
The zip with all needed files : https://drive.google.com/file/d/1YAMZF0J...mDRpP/view
Activate developer mode and get a root shell:
./adb device
./adb root
./adb remount
./adb push playstore.apk /system/priv-app/
./adb push playservices.apk /system/priv-app/
./adb push gsf.apk /system/priv-app/
./adb install -r gsf.apk
./adb install -r playservices.apk
./adb install -r playstore.apk
./adb push libAppDataSearch.so /system/lib/
./adb push libconscrypt_gmscore_jni.so /system/lib/
./adb push libgcastv2_base.so /system/lib/
./adb push libgcastv2_support.so /system/lib/
./adb push libgmscore.so /system/lib/
./adb push libgoogle-ocrclient-v3.so /system/lib/
./adb push libjgcastservice.so /system/lib/
./adb push libjingle_peerconnection_so.so /system/lib/
./adb push libleveldbjni.so /system/lib/
./adb push libnative.so /system/lib/
./adb push libsslwrapper_jni.so /system/lib/
./adb push libvcdiffjni.so /system/lib/
./adb push libwearable-selector.so /system/lib/
./adb push libWhisper.so /system/lib/
Then reboot and go to the android settings, apps and give all the permissions to the apks installed. Start Play Store, do not input anything, just exit.
The following commands should also be executed on the RockPro64 to prevent occasional Google Play Services errors: So run the beginning commands and get into adb shell and run these commands:
./adb shell
pm grant com.google.android.gms android.permission.ACCESS_COARSE_LOCATION
pm grant com.google.android.gms android.permission.ACCESS_FINE_LOCATION
Reboot again.
Finish
(10-20-2018, 12:49 PM)Domo Wrote: How to install PlayStore
./adb device
./adb root
./adb remount
./adb shell
Reboot again.
Finish
I downloaded the platform-tools from this post and the 8.1.2 post, but if I diff the files they are the same.
Incorrect link for this one?
This is working correctly.
How did you come across the steps?
(11-05-2018, 12:55 AM)chillaranand Wrote: Hi,
Hey, I have also a Tinker Board and the steps for installing Playstore are the same.
So i test the same prozess on the RockPro64 and it works :-)
(11-03-2018, 02:21 PM)Hi,The zip file is not accessible anymore. Could you please update the link?I am interested in adding Google play store support to the following 7.1.2 tablet: https://www.glorystartouch.com/product/K...et/NEB-215. Currently when I try binaries from apk-mirror, I get the following error with Google Services Frameworkjava.lang.RuntimeException: Unable to get provider com.google.android.gsf.settings.GoogleSettingsProvider: java.lang.SecurityException: You need MANAGE_USERS permission to: get the profile parentIt has Android version 7.1.2 and running on a Rockwell RK3399 Cortex A72 processor.Thanks,Abid.rookieone Wrote:
./adb device
./adb root
./adb remount
./adb shell
Reboot again.
Finish
The zip file is not accessible anymore. Could you please update the link? I am interested in adding Google play store support to the following 7.1.2 tablet:
Thanks,
Abid
./adb device
./adb root
./adb remount
./adb shell
Reboot again.
Finish
I played with it a little and I successfully installed Play Store using apks downloaded from apkmirror.
At a time of writing this post I used there versions:
https://www.apkmirror.com/apk/google-inc...-download/
I just renamed the files to playstore.apk, playservices.apk and gsf.apk and installed using this guide.
I decompressed the renamed playstore.apk to playstore.apk.zip and copied all the libs via adb.
  Difficulty installing Android on Rockpro64 spammycheese 0 2,688 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 2,594 06-04-2022, 12:18 AM
Last Post: grobbs
  Android TV miguelangelaj 2 2,886 06-03-2022, 11:23 AM
Last Post: miguelangelaj
  Control Fan in Android miguelangelaj 2 2,368 06-03-2022, 11:22 AM
  Slash TV Android for RockPro64 Wizzard 12 10,790 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 2,615 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 24,501 04-16-2021, 02:13 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 3,935 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 27,489 02-13-2021, 12:52 AM
Last Post: chisteven
  RockPro64 line out/headphones in Android 9 Wizzard 0 2,901 11-20-2020, 04:15 AM
Last Post: Wizzard
